Old 01-22-2026, 12:20 PM   #1
BBQdDude
BBQdDude's Avatar
Drives: 2010 Chevy Camaro 2SS RS
Things to look at when buying used convertable?
What are things on the convertible top that I should look out for when buying used?
Also how big of a difference does an aftermarket wind deflector make?
BBQdDude is offline   Reply With Quote
Old 01-22-2026, 04:44 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Operate the top to verify that it functions smoothly and correctly. Keep in mind that most extended warranties don’t cover the convertible top so you’ll want to be confident that it is working properly.
Check for separation of the rear glass from the convertible top.
https://www.camaro6.com/forums/showthread.php?t=604625
https://www.camaro6.com/forums/showthread.php?t=519083
Also check the rear quarter panel plastic trim to verify it functions correctly.
https://www.camaro6.com/forums/showthread.php?t=562083
Mark114 is online now   Reply With Quote
Old 01-23-2026, 06:27 AM   #3
ember1205
Hot Camaro
ember1205's Avatar
This pretty much nails it, especially the part about the extended warranties explicitly NOT covering anything to do with the convertible top OR the mechanical components that operate it. That's a pretty big exclusion on these cars.
I'd also suggest looking specifically at the weather stripping all around when you operate the top, make sure the tonneau seats correctly and that it operates smoothly, and check for signs of water leakage (wet or musty carpets, interior staining, etc.).
Old 01-23-2026, 07:41 AM   #4
BBQdDude
BBQdDude's Avatar
I knew about the glass separation issue but not the other things. I really appreciate the heads up and you taking the time to reply. I will add it to my data of things to review with the top when the time comes . Looking at December when I retire.
