Old 09-16-2019, 01:06 AM   #1
Kevin_S17
Kevin_S17's Avatar
Drives: 2017 2SS M6 Vert Summit White
Sliding panel broke
I use my top ALOT. Some days I will cycle my top 6x’s. I’m know that this issue has happened to others. I had no warning. No weird noises.
Not sure of the precise part name but the piece that slides on the metal track that pushes the plastic panel that hides the top mechanism when the top is down broke. This caused the panel not to retract when I tried to put the top up. The panel then popped the top plastic piece behind the drivers seat and broke the sliding panel.
Going to the dealer tomorrow to order the pieces so it can be repaired. Not sure why it did not retract. I had no idea it was happening since it was on the drivers side until it was too late.
2017 2SS M6 Vert Summit White; aFe CAI, E85, dyno tuned; Bigworm Graphix, various exterior mods
Kevin_S17 is offline   Reply With Quote
Old 09-16-2019, 03:38 PM   #2
HogmanZL1
HogmanZL1's Avatar
Drives: 2018 ZL1 Convertible
this happens often enough my dealer had all the replacement parts in stock. i was in and out within 1 hour. good luck!
HogmanZL1 is offline   Reply With Quote
Old 09-16-2019, 03:59 PM   #3
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
Not sure if you read thru this thread:
https://www.camaro6.com/forums/showthread.php?t=531151
My issue was the panel did not break but would not open. Was like that from when I first bought my car earlier this year (it was a leftover 2017, purchased new in Feb '19).
This is the link to the TSB which does indicate potential for parts breaking:
https://static.nhtsa.gov/odi/tsbs/20...39149-9999.pdf
Good Luck!
lcd550 is offline   Reply With Quote
Old 09-16-2019, 04:13 PM   #4
drewspr00
drewspr00's Avatar
Drives: 2016 Camaro 2SS Convertible A8
Does anyone have the part number for the plastic piece that slides along the aluminum rail? It's the one that actually moves the plastic door.
drewspr00 is offline   Reply With Quote
Old 09-16-2019, 04:36 PM   #5
Nitefall17
Drives: Camaro 1SS A8 Vert
Yes
Nitefall17 is offline   Reply With Quote
Old 09-17-2019, 06:33 PM   #6
drewspr00
drewspr00's Avatar
Does anyone have the part number for the plastic piece that slides along the aluminum rail that also would like to share that information with me?
Old 09-17-2019, 09:46 PM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I trust it is not molded into the part...
The closest I could get is the tonneau hinge, but it’s not clear that it comes with the cover. Might be worth a stop at the dealer parts counter or a call to that gm parts guy.
https://www.gmpartsoutlet.net/oem-pa...bC12Ni1nYXM%3D
Old 09-21-2019, 01:03 AM   #8
Kevin_S17
Kevin_S17's Avatar
Went to the dealer and was told that this has happened enough that there is a TSB for it. Also, there is a “kit” they ordered. When it gets replaced I will post the info from the service invoice.
Old 09-22-2019, 07:05 AM   #9
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Good deal, thanks... will be looking for it.
Old 10-03-2019, 11:26 AM   #10
Yasha
Drives: 2017 2SS
Did your top get stuck in the up or down position? Looks like down but want to confirm...
Yasha is offline   Reply With Quote
Old 10-09-2019, 07:03 PM   #11
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
SOB, 2nd time in 13 months.
Just happened, put the top down and there is a gapping hole, the sliding panel stayed stuck (been telling these dealers it makes noise, oh that is normal), so pulled it back, hoping to avoid a dealer visit, and it began to pull up the panel. Good times.
Guess I will have them look at the squeaky front brakes and jolting transmission issue.
Anyone have a TSB on the brakes issue?
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 10-12-2019, 10:12 AM   #12
Indy_62
Drives: 2017 2SS / 2003 S10 Crew Cab
I had the driver side replaced this week. I asked the tech why the window regulator would possibly need to be replaced. He explained that the extra clip added to the newly designed trim panel attaches to a slot in the regulator and earlier version regulators did not have the slot. The entire repair took less than an hour. Kudos to McLarty Daniel Chevrolet in Springdale, Ar for a great service experience!
Never say never!
Indy_62 is offline   Reply With Quote
Old 03-27-2020, 03:25 PM   #13
FarmerFran
FarmerFran's Avatar
SO has this been designed out for the later MY cars? I.E. fixed now for later MY?
Old 03-27-2020, 05:52 PM   #14
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Redesigned? Yes.
Problem fixed? Maybe...
17rsvert is offline   Reply With Quote
