Old 01-23-2018, 07:55 AM   #1
Godfatha
Drives: 2016 2SS Mosaic Black Convertible
Convertible - Rear Window Glue Coming Loose
Didn't find this issue in the forum.
My rear window (upper passenger side corner) has come loose creating a gap between the window and the ragtop. This looks to be an issue where the glue has failed. Not sure if it is because of the recently cold weather or some other factor. Has anyone else experienced this, and if so, what is a good fix? I've talked to my dealer and he said the entire top would need to be replaced, but I would think there should be a way just to glue it back. Trying to avoid an expensive fix for what should be a relatively simple one.
Godfatha is offline   Reply With Quote
Old 01-23-2018, 08:36 AM   #2
Bigdog9586
Drives: 2016 Z06 coupe
Shouldn’t it be covered under warranty?
Bigdog9586 is offline   Reply With Quote
Old 01-23-2018, 09:17 AM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I believe I saw a post in the forum a while back that there was a TSB issued for that problem and the fix is to replace the convertible top.
Old 01-23-2018, 04:38 PM   #4
Godfatha
Thanks guys, I will check.
Old 01-23-2018, 06:38 PM   #5
KLG
KLG's Avatar
Had that issue with mine. The dealer service advisor stated the only fix was to replace the top.
So, in late November, the full top was replaced under warranty.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 01-23-2018, 09:12 PM   #6
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Mine is starting to do the same thing. You can see the air going between the glass & top as if it's starting to separate.
classicrockr is offline   Reply With Quote
Old 02-08-2018, 04:46 AM   #7
classicrockr
Those of you that got your tops replaced - Is this what your windows looked like?
Old 02-08-2018, 08:23 AM   #8
Gen6 softtop
Drives: Hyper blue 1ss convertible 6 sp
Curious also will have to check mine come spring
Gen6 softtop is offline   Reply With Quote
Old 02-08-2018, 08:30 AM   #9
motorhead
Everytime I start thinking ofa convertible stuff like this pops up. First the mess that was the gen5 cars with convertible tops now this. Guess im back on a wait and see train. Im starting to think that GM should stop trying to do convertibles.
Old 02-08-2018, 08:48 AM   #10
Gen6 softtop
I have no complaints about my vert love it. If the top needs replacing due to window, I have no doubt they will fix it. If it needs it like I said freaking love this car no complaints would highly recommend a vert
Old 02-08-2018, 01:28 PM   #11
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
I agree i am sure if mine starts they will fix it under warranty I only have 2k on mine so my warranty will expire well before I hit 36k
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 02-08-2018, 03:29 PM   #12
CyberGuyPR
CyberGuyPR's Avatar
Drives: '16 vert 2LT RS NPP
Also 2k only here. I need to check it when the car comes out of hibernation.
CyberGuyPR is offline   Reply With Quote
Old 02-08-2018, 10:01 PM   #13
kaydoe
Drives: 2017 Camaro 2ss convertible
Mine was a lot worse, the dealer replaced whole top no charge
kaydoe is offline   Reply With Quote
Old 02-09-2018, 01:28 AM   #14
GroundhogSS
GroundhogSS's Avatar
I've got 20K miles here. No problems.
Richard
Delivered: 08/15/2016
#TeamBeckyD
