Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 09-19-2017, 10:37 PM   #1
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
[ASKED] Camaro SS No-Lift Shift feature questions
Al,
My primary reason for asking this question is to confirm that the No-Lift Shift (NLS) algorithm is functioning properly on my 2017 1SS. At this year's Camaro Fest in Bowling Green, I asked during the Q&A about the NLS algorithm and you confirmed it was enabled on all 6th gen manual transmission Camaro SS cars. I recently tested the feature out and it did not work how I was expecting. Before I use it again, I'd like to confirm I'm executing it correctly and not just banging into a 6500 RPM limiter if that's not how the feature is supposed to work. Could you please help me clear up the following questions:
1. When the accelerator pedal is at 100% and remains there throughout the procedure, what should engine speed do as the clutch pedal gets depressed and the shift lever moved to the next gear? Does engine speed jump to and get held at 6500 RPM or is engine speed supposed to reduce?
2. What are the enable criteria for the no-lift shift algorithm?
3. Is the algorithm tuned exactly the same between the SS 1LE and SS without 1LE package?
Background information and follow-up questions:
When I perform a no-lift upshift, as I depress the clutch the engine speed will go to 6500 RPM and stay there similar to this video below. I'm concerned that the feature is not working as intended and it might just be hitting a normal rev limiter. Another example is in this post as well: http://www.camaro6.com/forums/showpo...1&postcount=24
However, others (specifically with the SS 1LE) have PDR videos of executing a similar shift and engine speed drops to match up with the next gear. Reference this video:
Which video demonstrates the NLS feature operating properly? Does PTM in the 1SS 1LE impact the NLS algorithm?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline
Old 09-20-2017, 03:55 AM   #2
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I thought all manuals were no lift shifts. Dont know anything about the electronics. None of my cars had that stuff.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline
Old 09-20-2017, 06:51 AM   #3
Yes, I asked All (no pun intended) this very question and the answer was All V8 6th Gen Camaros have no lift shift.
However, from the threads we have here this is a great question.
mlee is offline
Old 09-20-2017, 05:34 PM   #4
Blu Ray
ALWAYS-N-BOOST
Blu Ray's Avatar
Drives: 2021 ZLE A10
Send a message via AIM to Blu Ray Send a message via Yahoo to Blu Ray
Great Question
2012 1LS M6 Black-Sold
2013 2LT M6 BluRay- Sold
2015 1SS 1LE M6 Black-Sold
2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10
Blu Ray is offline
Old 09-20-2017, 08:53 PM   #5
vtirocz
vtirocz's Avatar
Here are some of the No Lift Shift threads on this forum. A lot of folks have questions about this feature and would really appreciate clarification on how it's supposed to work so they don't damage their cars.
http://www.camaro6.com/forums/showthread.php?t=508133
http://www.camaro6.com/forums/showthread.php?t=503081
http://www.camaro6.com/forums/showthread.php?t=424904
http://www.camaro6.com/forums/showthread.php?t=467834
http://www.camaro6.com/forums/showthread.php?t=485532
http://www.camaro6.com/forums/showthread.php?t=467730
http://www.camaro6.com/forums/showthread.php?t=484778
http://www.camaro6.com/forums/showthread.php?t=473074
http://www.camaro6.com/forums/showthread.php?t=486710
http://www.camaro6.com/forums/showthread.php?t=447018
http://www.camaro6.com/forums/showthread.php?t=506459
http://www.camaro6.com/forums/showthread.php?t=474354
http://www.camaro6.com/forums/showthread.php?t=409505
http://www.camaro6.com/forums/showthread.php?t=428763
http://www.camaro6.com/forums/showthread.php?t=480770
http://www.camaro6.com/forums/showthread.php?p=9820805
http://www.camaro6.com/forums/showthread.php?t=501740
vtirocz is offline
Old 09-21-2017, 08:45 AM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Me, too....I haven't yet tried it in the ZL1 1LE....
Mr. Wyndham is offline
Old 09-21-2017, 11:09 AM   #7
ChadFarr
Instagram: @SSAVAGEVERT
ChadFarr's Avatar
Drives: 2016 SS M6 Vert
I'm curious as well to this answer. I have a manual 1SS Convertible and when I attempt a no lift, I'm not hearing the sputter that the vehicle gives off. My question Is it all Manuals or Only manual coupes?
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build
ChadFarr is offline
Old 09-21-2017, 07:17 PM   #8
vtirocz
vtirocz's Avatar
When will the first question get answered? I'm anxious to get the details on this one!
vtirocz is offline
Old 09-21-2017, 07:29 PM   #9
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
The process is posted in the header of this forum.
There is no guarantee it will even be asked.
Expect possibly 2 weeks for selection. Another week for voting and the winner get passed on to Al and the Camaro team.
It could take...a week? 2 weeks, a month for an answer from them
BradfordCamaro is offline
Old 09-24-2017, 12:13 PM   #10
vtirocz
vtirocz's Avatar
Moderators,
What's the timing on the first set of questions being selected and poll set up?
Thanks for adding this section!
vtirocz is offline
Old 09-24-2017, 12:53 PM   #11
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
I'm not sure why there is so much uncertainty with this feature maybe because it's not listed in the manaul but it definitely does not work in touring mode and it's painfully obvious when it works and when it doesn't.
You either get a smooth shift or you don't.
I guess getting an official answer will clear things up
thescreensavers is offline
Old 09-24-2017, 05:10 PM   #12
vtirocz
vtirocz's Avatar
In the various threads on this topic, several folks are saying it works in any mode. You say it definitely does NOT work in touring. If it's painfully obvious when it is and is not working, then there wouldn't be so many threads and debates on this feature.
The question in the first post is clear. Two No lift shifts behaving differently as shown in the videos. Which one is working as intended, or was the feature in the 1LE tuned differently?
I really would like to hear straight from the team that designed it to confirm exactly how it's supposed to work.
vtirocz is offline
Old 09-25-2017, 10:15 AM   #13
Deakins
Drives: 2017 2ss, m6
I'd love a true answer to this as well. I'm not even certain how it's supposed to work...but my 2017 SS in track mode works exactly like the first video. There doesn't seem to be a whole lot of rev matching going on...it just lays up at the limited from the looks and sounds of it so I don't use.
Deakins is offline
Old 09-25-2017, 01:33 PM   #14
Mr. Wyndham
Moderators,
Since we just launched the section, let's allow some time for some discussion to take place. Say, another week or so. Then - we'll post a poll for voting the week after that...and when selected - give another 2 weeks to get a good response from Al and the Team.
So...at most - a Month from now.
