Old 07-27-2017, 11:19 PM   #1
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
SS No Lift Shift Proof!
I've recently seen quite a few threads about cars having or not having NLS, what it does or what it should sound like, what modes you have to be in, should the RPMs drop etc. I thought I'd post this video in a new thread to make it more easily searchable. Launch control is only available in stabilitrack competitive and the PTM modes but I use NLS all the time with traction control on. I do not believe this needs to be done in sport or track mode (touring works too but I never use it).
Vehicle: 2017 Camaro SS 1LE
Settings used:
  • Sport Mode
  • Stabilitrack Competitive (double tap traction control) for first run
  • Launch control (stop and floor accelerator)
  • Traction on for 2nd run
Throttle stays at 100% throughout the run and I purposefully shifted slowly to show the effect of NLS
Mods: thought I'd post this here as its about the settings used (whether they matter or not) for NLS, not necessarily the video.
EDIT: ran another test to see what happens if you don't release the clutch after shifting with NLS.
  • Sport Mode
  • Traction fully on
  • Full throttle to redline, clutch in, shift, and don't let the clutch out
  • Throttle at 100% the whole time
You can hear the NLS fart as RPMs drop and hold where they should be for the next gear (2nd). Then when I release the clutch a 2nd later, the car applies full power automatically.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 07-27-2017, 11:26 PM   #2
HyperBlue1LE
Drives: 2017 SS 1LE
What were you expecting to happen? your revs to stay at 6k?
HyperBlue1LE is offline   Reply With Quote
Old 07-27-2017, 11:27 PM   #3
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
No, that seems to be a common misconception. Many people on this forum seem to think that NLS holds the RPMs when you put the clutch in when it in fact lets them drop to reduce driveline shock.
Old 07-28-2017, 12:31 AM   #4
SuperSteveSS
SuperSteveSS's Avatar
Drives: 2017 ss
My rpms do not drop when I do it.
SuperSteveSS is offline   Reply With Quote
Old 07-28-2017, 12:48 AM   #5
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
Even if you shift slowly like the video? If I shift quickly it's much less noticeable that the RPMs are dropping since the shift window is so short but they still do, albeit with the NLS exhaust fart. The real test it to clutch in like you're going to use NLS and shift into the next gear but don't let the clutch out.
Old 07-28-2017, 01:30 AM   #6
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Mine don't either...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 07-28-2017, 02:18 AM   #7
BFella
BFella's Avatar
Drives: 16' Supercharged 1SS
How'd you get that video - Is it like an option in the car or what?? I keep seeing them around and I need it :O
760RWHP Magnuson 1SS
BFella is offline   Reply With Quote
Old 07-28-2017, 02:24 AM   #8
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Go Pro cameras very versatile...
Old 07-28-2017, 02:35 AM   #9
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 07-28-2017, 04:10 AM   #10
SuperSteveSS
Drives: 2017 ss
If anything, they go up... but it sounds exactly like the car Libertyhill posted.
Old 07-28-2017, 06:33 AM   #11
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Could you post a video with that test you've described above? I will give that a shot
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 07-28-2017, 06:52 AM   #12
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
...That's the factory PDR (Performance Data Recorder). No GoPro there...
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 07-28-2017, 07:08 AM   #13
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
Love that PDR. How do you get that?
SSTony is offline   Reply With Quote
Old 07-28-2017, 07:10 AM   #14
Dfelux
Drives: 2016 SS Hyper Blue
Tried this on the way to work today, definitely hit the rev limiter. Anybody else notice both these vids are 1LE's? Do the non 1LE camaros a have the NLS feature?
Dfelux is offline   Reply With Quote
