Old 03-26-2016, 03:25 PM   #43
chris227
chris227's Avatar
Had no problem with the amp turning on after having the x3 connector unplugged all night. Everything still works as normal just the bass does not drop like it did with it connected.
Old 04-03-2016, 01:47 PM   #44
chris227
chris227's Avatar
After having the X3 connector disconnected for a couple weeks now, I love the stereo much more. One side effect is I don't get the ticking sound when I turn on my blinker. Reconnected it the other day to make sure it wasn't something else and the sound was back. IMO sounds better with X3 disconnected.
Old 07-19-2016, 04:42 PM   #45
A_Work_Of_Art
Drives: 2016 Camaro SS
Reviving an old thread.
Does anyone have the wire diagram for the x3 connector? I am getting sound issues that could be related to the ANC and I need to know what wire to clip for the Mic on the x3 connector. Thanks in advance fellas!
- Art
| 2SS Camaro |Garnet Red| Adrenaline Red| NPP| MRC| 6SPD| CAI Intake| Mishimoto CC|
A_Work_Of_Art is offline   Reply With Quote
Old 07-27-2016, 08:22 PM   #46
Skydiver32
Originally Posted by gblaue View Post
You can ask me questions, I'll answer what I can, but I am limited to what I can answer.
For the 1SS...Do you have any suggestions as to where to tap for a remote? /Thanks..
Skydiver32 is offline   Reply With Quote
Old 01-22-2017, 06:24 PM   #47
shags
shags's Avatar
Drives: 2016 SS Garnet Red A8
im looking for the same
shags is offline   Reply With Quote
Old 01-22-2017, 06:26 PM   #48
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
http://www.camaro6.com/forums/showthread.php?t=474059
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
Old 03-20-2017, 07:59 PM   #49
ctrlz
The below image shows a Bose amp in a 2LT.
The connectors right to left are X1 (black), X2 (green), X3 (black), and X4 (brown). The X1 and X2 connectors are the same for all Bose installations.
X3 varies with installations in a 2SS getting additional wires.
In this photo X3 has only one wire (gray with green stripe, GY/GN) in pin 1 - Low speed GM LAN serial data.
X4 has 4 wires in pins 3-6:
3 WH/GN MOST serial data (-)
4 GY/VT MOST serial data (+)
5 WH/GN MOST serial data (-)
6 GY/VT MOST serial data (+)
pin 14 is WH/VT MOST control, and I believe it is hidden here. It is definitely present on the 2SS harness.
Old 03-24-2017, 11:14 PM   #50
Antista1974
Antista1974's Avatar
Drives: 2016 Camaro 2ss 2nd cat delete
you cant fade to right because you are connected to the left only....but you are also louder now because you basically bridged your wires...you went from 4 wires to 2 which changed/doubled your power probably changed your ohms from 8 to 4 or 4 to 2 or 2 to1 especially if you are using a mono block amp....which most after market sub amps are mono block...
Antista1974 is offline   Reply With Quote
Old 10-02-2017, 11:56 AM   #51
mako22
mako22's Avatar
Drives: 2017 HB 2SS
Thanks for this - so if I wanted to cut the wires for active noise cancellation in my 2SS - which wires would I cut?
mako22 is offline   Reply With Quote
Old 10-02-2017, 01:36 PM   #52
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
See post 9 here:
http://www.camaro6.com/forums/showthread.php?t=506670
Should make sense from that I hope.
Ecchi667 is offline   Reply With Quote
Old 10-02-2017, 08:18 PM   #53
mako22
mako22's Avatar
Drives: 2017 HB 2SS
Originally Posted by Ecchi667 View Post
See post 9 here:
Thanks!!!
Old 06-29-2019, 01:08 AM   #54
Sai B.
Drives: 2016 Camaro 2LT V6 RS Bose
Originally Posted by BadBillyJack View Post
Not saying you did something wrong, but I do believe you looked at the wrong schematics.
Where did you get this information? Cause I can’t find a service manual anywhere.
Sai B. is offline   Reply With Quote
Old 01-02-2022, 08:53 PM   #55
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Easy Amp Installation
Took me about 2 hours because I was being picky. But simple hookup for those wanting to add aftermarket subs to your 6th gen. Granted this is in a 2SS with the bose system but I didn't use anything off the bose amp I used the drivers side rear speaker. For those without the bose setup you can run off one of the rear side speakers.
1. Hooked up the kicker sub converter to the rear speaker on the passenger side. BU/GY Left/Rear Subwoofer Speaker Control (+),
and GN/BK Left/Rear Subwoofer Speaker (-)
2. Ran the power wire to the battery with a fuse link in the line.
3. Made my own ground point as you can see the brown wire in the picture.
4. Ran the remote lead from the kicker converter to the amp.
Could have been done in 1 hour but I kept running back to autozone for stuff i thought I had but couldn't find anything.
WiggyB is offline   Reply With Quote
