02-23-2016, 09:12 AM | #1 |
Drives: 2010 Camaro SS Join Date: May 2009
Bose Wiring Diagram
Has anyone come across a wiring diagram for the Bose system in a 2SS? I'm looking to add an amp/sub to my existing system.
02-25-2016, 01:30 PM | #2 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Just look up the model # on the amp in the trunk and do a google search. I have a 2lt so dont know if the amp is the same. Thats what i did to figure out which wires to tap into. The bose amps are used in many different vehicles. found mine in a Cadillac forum i believe.
02-27-2016, 07:10 AM | #3 |
This is what I was able to find as far as the model information, but all I've been able to find online is people selling them. I haven't been able to locate any type of wiring diagram telling me what wires to tap in to. All I need is a remote turn on lead and the correct speaker wires so I can hook up my converter and get rca outs for my amp.
02-27-2016, 09:33 AM | #4 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
02-27-2016, 10:44 AM | #5 |
wrong info
03-02-2016, 07:15 AM | #6 |
Do you remember what color wire you tapped into for the remote turn on lead? Last night I had tied into one of the fuses in the box in the trunk, but evidently those fuses are always live, because my amp remained on whether the car was on or not.
03-02-2016, 08:56 PM | #7 |
I'm going to be redoing my box in my trunk this weekend. I'll take some pics of where I wired it up. It's blocked right now. That's what I have to redo so I can have access to the stock amp, it's blocked right now.
03-13-2016, 12:28 PM | #8 | |
03-13-2016, 01:24 PM | #9 |
It appears you have the RPO UQA-CM8* (*without CM8) and it looks like you're tied into the X1 connector;
Pin 1 color BU/GY Left/Rear Subwoofer Speaker Control (+), and Pin 5 color GN/BK Left/Rear Subwoofer Speaker (-) Low Reference. What converter are you using, and where did you tap into for the remote turn on lead?
03-13-2016, 01:35 PM | #10 | |
03-13-2016, 01:43 PM | #11 | |
03-13-2016, 01:45 PM | #12 |
The front speakers are the sub woofers. Tested each wire to get what I needed. But yes you are right. It is a sub and the color would be different.
03-13-2016, 01:51 PM | #13 |
Not saying you did something wrong, but I do believe you looked at the wrong schematics.
03-13-2016, 01:58 PM | #14 |
Had no schematics to look at. You are the first to actually post something in reference to this amp.Thank you. I did look at the ATS and Corvette forums to get in the general area to look.
