Old 11-25-2025, 11:51 AM   #1
cajunzl1
Drives: 2018 ZL1
BMR Motor Mounts
Anyone had any issues installing these? thinking about a set while I'm installing headers.
Very few videos online showing the install!
Thanks
Cajun
cajunzl1 is offline   Reply With Quote
Old 11-25-2025, 12:07 PM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Here's what they look like "installed"
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 11-25-2025, 12:29 PM   #3
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Thanks
Cajun
Hey buddy, these are awesome... most of our clients do these with headers like you mentioned, and so did I when I started modding my car.
They are a great addition with no negative effects that I have seen.
I think they could have some from the factory.
Installing with headers is the best time, as you have great access. The hardest part I remember was simply getting to all of the bolts... I recall the passenger side being a PITA.
But the time / cost is well worth it IMO.
Happy to answer any other question you may have...
Old 11-25-2025, 01:48 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
https://www.camaro6.com/forums/showthread.php?t=615916
758 HP/ 804 TQ
Old 11-25-2025, 02:41 PM   #5
cajunzl1
Drives: 2018 ZL1
So no major hurdles when the exhaust manifolds are removed? Hopefully they will make the header install much easier as well!
Thanks for all the responses!
Old 11-25-2025, 03:02 PM   #6
SOCAL.M6.ZLE
Correct, they make the install much better, you save weight, and it makes removal + install easier down the road when you do more work to the car...
If you wouldn't mind, can you let us know the weight of the OEM Mounts? I looked but couldn't find it in my notes.
Old 11-25-2025, 03:34 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Thanks
Cajun
I'm also a fan of my set. As noted, doing them along with headers at the same time is the way to go. No big issue with install, just take your time and get it all lined up. Likely will need to final-tighten everything after it's all installed and placed appropriately.
Mods being installed-
Old 11-25-2025, 04:05 PM   #8
SWFLZL1
Drives: 2022 ZL1
I put them on mine while doing headers, not too bad to do, just a little time consuming. Made it real easy to slide the headers in.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 11-25-2025, 07:34 PM   #9
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
I have a feeling either my block was mis machined or the car was built incorrectly. BMR mounts wouldnt bolt up correctly (holes were off about 1/2") so I purchased some stainless steel plate and fabricated my own plates that bolt to the cradle. LET ME BE CLEAR HERE: I do NOT believe this was something related to BMR.
When I bought the car brand new, ordered from a dealership owned by my family, it wouldnt align correctly and would pull hard to the left when I floored it. Only after buying BMR on car adjustable everything for the rear was the car able to be aligned correctly. The shop that did the alignment said there wasnt enough adjustment to bring it into spec with the stock parts.
At any rate, I absolutely LOVE these mounts! They shed a fair amount of weight and on a ZL1-1LE, you barely notice any additional harshness. The only caveat IMO, is if GM built you a Monday or Friday car, you might have issues. My car was built right after the 2019 strike ended BTW.
GreenZLE is offline   Reply With Quote
Old 11-25-2025, 07:52 PM   #10
ZLRob
Super Stock
ZLRob's Avatar
You know there may be a chance that the sub frame cradle assembly might have been installed shifted too much to one side. I remember that was sometimes a prominent thing on some of the 90's Hondas and so when it came time to do an alignment if things were too far off, sometimes the car would need to come off the alignment rack and the entire assembly needed to be unbolted then shifted one way with a prybar to allow things to get back into proper spec.
I don't know if our cars are like that, but it's an idea.
758 HP/ 804 TQ
Old 11-25-2025, 07:55 PM   #11
GreenZLE
You might be right! Maybe the lower cradle was made wrong? I could see that throwing the wheelbase off. Maybe I'll find that it was in a bind when I pull the engine next week!
Lots of mods planned over the winter!
