Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
BMR MM010 engine mounts
Just wanted to throw this out there because I feel like it hasn't been talked about enough.
I recently did my oil pump and a DOD delete on my 17 Z. While we had the engine out I found that the old engine mounts were not only cumbersome and incredibly in the way but one was already failing with only 35K on the clock. I believe it was the driver's side. I took it upon myself during the build to go ahead and replace the mounts since we were in there. Not only did it free up TONS of working space within the bottom side of the engine bay but it increased the confidence of the overall drive now that they are on with no notable changes in NVH (and I'm SUPER sensitive to those sort of changes). Matter of fact I would even go on to say that it helped smoothen things up while at idle. During install, I have to state that BMR did not have the foresight to install some sort of provision to hold the transmission hard lines running towards the front of the car, after a phone call they confirmed that, and there is nowhere else to tie them up to, but they indicated and after a long examination I confirmed that there should be no issues with that moving forward. There were no detectable changes in knock and there was no need to desensitize the OE knock sensor calibration on HPT. As with anything your mileage may vary, but I am entirely happy with the positive changes it induced on the way my Z drives now. If you're on the fence about them, don't be. I think the majority of you will be very pleased with the outcome.
758 HP/ 804 TQ |
![]() Drives: 2022 ZL1 M6 Join Date: Mar 2022
Nice write up thanks for the info
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I agree, these are bad ass... i did mine at the same time as the headers... the throttle response feels alot tighter, and now with a CAM... you get plenty of feedback.
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
Petro-sexual
Good information! Would you say these are a little lighter than OEM, too?
Super Stock
They are apparently 6 lbs lighter if I remember correctly AT MINIMUM.
758 HP/ 804 TQ |
![]() Drives: 22 LT1 Join Date: Apr 2022
Nice!
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
I agree with OP, installing those mounts is a good choice when doing headers. I also installed the tunnel brace instead of stacking washers to move the factory brace away from X-pipe.
#8 |
Super Stock
What's the purpose of the tunnel brace? I thought it already had one from the factory? Stronger?
758 HP/ 804 TQ |
#9 |
Yes sir there was already a brace in that location. My issues was the new exhaust was larger and it was going to come in contact with the factory brace. I could’ve just shimmed it with a spacer or washers but liked the cleaner look. The aftermarket isn’t necessary if you shim the factory brace.
#10 | |
The factory brace is flat, so when you upgrade to larger exhaust, the HALO drop bracket with lower center section provides alot more space.
#11 |
![]() Drives: 22 ZLE 6MT Join Date: Nov 2017
Funny I just got done installing the same motor mounts along with the LG header system. Then started getting a rattle from the tunnel brace and ordered the HALO brace lol
Looks great and well done. |
#12 |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
ZLRob was your bike track/road raced? Drag racing? Motor mounts bad at 30K is ridiculous on GM part, I just hit 30K this past Friday, a week ago all my gauges went crazy and stopped working for 10 mins when I cranked it up while out on the town.
Then a 02 sensor code would not clear, but I had been noticing the volts on my radar detector was dropping to 11 volts while running, the 5 year battery was giving up, it always started but I could tell. Got the new battery dropped shipped yesterday and on today, the 02 sensor finally cleared, a old battery can throw all kinds of bugs. I'm going to look at motor mounts also, engine warranty go's out next month, oil pump, and cam in my future for sure. |
#13 | ||||
Super Stock
758 HP/ 804 TQ |
#14 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Considering adding these to my 2017. I am a bit hesitant with the potential for increased NVH.
I ran some poly Hinson mounts on my C6 for a while and it did have more NVH. It was not bad at all but I found over time I was starting to get a bit tired of it. Would be nice if BMR would make a version with conventional rubber bushings instead of polyurethane. Could get more clearance but have better NVH control I would think. |
