Old 12-10-2023, 10:22 AM   #1
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
Wheel Fitment - Camber Plates
Hey fellas....I'm dropping down to 19" apex wheels on my regular zl1....11" fronts and 12" rears....for those that have done this did you have to get the camber plates to eliminate the front wheel poke or not? I'm not trying to not get them just want to have all the parts I need when I make the switch....thanks in advance....
IndyZrider is offline   Reply With Quote
Old 12-10-2023, 02:57 PM   #2
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Mine still had some poke at -1.75, so they would need to be rolled in pretty good to flush them.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 12-10-2023, 04:09 PM   #3
IndyZrider
IndyZrider's Avatar
-1.75 was your ET? The ones I ordered have a 9 ET.....that should be farther in correct?
Old 12-10-2023, 04:10 PM   #4
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
The fronts won’t stick out any more than a stock ZLE which IMO looks pretty good. I would avoid camber plates if you can, they remove the rubber isolator at the top of the strut and replace it with a spherical bearing and it will affect the ride on the street. If you are tracking the car you probably want them. I had the Vorshlag plates and they worked well.
Sephx1 is offline   Reply With Quote
Old 12-10-2023, 04:12 PM   #5
Sephx1
Sephx1's Avatar
-1.75 camber is what I think he meant?
Old 12-10-2023, 04:19 PM   #6
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
Mine don’t poke on stock camber. I have your setup
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 12-10-2023, 04:22 PM   #7
IndyZrider
IndyZrider's Avatar
Awesome.....thanks for the replies....
Old 12-10-2023, 06:14 PM   #8
cdb95z28
cdb95z28's Avatar
Amount of poke is dependent on your camber # and the wheel offset.
You may not be able to get all the camber you want because you need to have adequate wheel/tire to strut clearance.
"KEEP THE FAITH"-Fbodfather
Old 12-10-2023, 08:19 PM   #9
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
That was camber setting. ET was factory 1le spec.
Old 12-11-2023, 06:20 AM   #10
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
I have Vorshlag camber plates on my car and didn't have any change in ride quality or NVH.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 12-11-2023, 06:26 AM   #11
Rapid_blue_zl1_22
You will probably have to trim the strut body like you do if you put OEM 1LE wheels on a regular ZL1. The inner barrel/lip of the wheel will contact (or be extremely close to) the strut body right above the strut bolts. Camber plates won't be a requirement though.
Old 12-11-2023, 10:28 AM   #12
IndyZrider
IndyZrider's Avatar
Hmmm.....I'll have to do some digging to see what you're talking about....
Old 12-11-2023, 02:04 PM   #13
Rapid_blue_zl1_22
https://www.camaro6.com/forums/showthread.php?t=526353
Old 12-11-2023, 02:04 PM   #14
PKG4U
Drives: 2018 ZL1
Not with APEX wheels. The strut shaving was recommended for me too back when I did it. If you get the right offset you do NOT need to shave the strut. It doesn’t contact. Buy the wrong ET and the wheel won’t even fit
