Old 04-03-2023, 07:38 PM   #1
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Factory Blower Build
My 19’ ZL1 A10 went under the knife today. Since I already have a 2650 on my C7Z I wanted to see how my ZL1 would run with the factory little guy. Build is as follows:
-Kong Regular Port w/2.30 upper
-LMP Blower Lid
-FRE Stage 2 Heads Rebuilt by LME
-.028 Head Gaskets “10.6:1” Compression
-BTR Stage 1 Cam +38% Fuel Lobe
-DSX Flex Fuel Kit
-XDI +65 Injectors
-LPE Big Bore HPFP
-JMS Voltage Booster
-DSX Aux Low Side
-C.H.E Trunnion Kit
-ATI Balancer w/9.25 lower
-Katech 103mm TB
-Roto Fab Big Gulp
-LMP Heat Exchanger
-Katech 174 T-Stat
-TSP 2” Headers
Guesses on power? I’m going to say 840whp on the MD-500 Mustang it will be dyno’d with.
Results 863/838
https://youtu.be/5dIzGAS7z6U
CamOnlyJabroni is offline   Reply With Quote
Old 04-03-2023, 08:08 PM   #2
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Love this build. I’ll be following, as I may eventually add cam and dsx low side to my Kong Stage X. Subscribed.
CW3SF is offline   Reply With Quote
Old 04-03-2023, 08:18 PM   #3
CamOnlyJabroni
It won’t be long. This shop doesn’t mess around with getting things done. He started this morning and got to where these pictures are.
Old 04-03-2023, 09:35 PM   #4
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
So you are running the jms voltage booster and the DSX aux kit? I was wondering if that was possible. Great info can’t wait to see your numbers.
ChadSZL1 is offline   Reply With Quote
Old 04-04-2023, 08:00 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
KingLT1 is online now   Reply With Quote
Old 04-04-2023, 08:37 AM   #6
CamOnlyJabroni
yes. I do the same thing on my C7Z and KingLT1 had it making over 1kwhp on E60. Low side was falling to right at 72-73 at redline. Commanding 82 with the mechanical regulator. C7 has a Cordes Aux low side.
Old 04-04-2023, 08:38 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Sweet build.
-MPI Blower Lid
-DSX Flex Fuel Kit
-XDI +65 Injectors
-LPE Big Bore HPFP
-DSX Aux Low Side
-C.H.E Trunnion Kit
-Katech 103mm TB
-Roto Fab Big Gulp
-LMP Heat Exchanger
-Katech 174 T-Stat
-TSP 2” Headers
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-04-2023, 09:28 AM   #8
adamjwilson
Drives: 2022 Camaro 2SS A10
Was wondering the same thing... jms voltage booster and the DSX aux kit?
Any advantage to running both?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 04-04-2023, 09:36 AM   #9
KingLT1
KingLT1's Avatar
It provides more fuel to the high side vs running stock in tank and auxiliary. When running E it never hurts to have more fuel delivery headroom.
Old 04-04-2023, 07:20 PM   #10
CamOnlyJabroni
Sweet build.
Old 04-04-2023, 09:47 PM   #11
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
-MPI Blower Lid
-DSX Flex Fuel Kit
-XDI +65 Injectors
-LPE Big Bore HPFP
-DSX Aux Low Side
-C.H.E Trunnion Kit
-Katech 103mm TB
-Roto Fab Big Gulp
-LMP Heat Exchanger
-Katech 174 T-Stat
-TSP 2” Headers
Guessing around 820whp. Interested to see how much boost and MAT temps you're making with the pulley combo and the rest of your setup. Looks like a stout combo
Old 04-05-2023, 07:27 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
850 uncorrected
'20 ZL1 Black "Fury"
Old 04-05-2023, 03:54 PM   #13
CamOnlyJabroni
Cam is in, heads are on. Plenty of PTV clearance. Was at .035 with no gasket. With the .028 puts me at .063.
Old 04-05-2023, 03:57 PM   #14
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Make sure you move and protect the harness.
