Old 10-20-2020, 05:31 PM   #1
sickss228
Drives: 18 ZL1 mostly stock
BTR Stage 2 numbers?
Looking to do a cam over the winter. I already have a Kong ported stock SC w/ NW 103 TB, 15% lower pulley, Kooks 2" headers w/ green cats (just bought the offroad pipes), Roto-Fab big gulp, Cordes Front mount expansion tank,Borla S type catback and a mighty mouse wild catch can. I have done a ton of research online but can't really find any numbers on guys running the BTR stage 2 cam only and w/ ported heads. I am narrowing my choices down to MTI, RPM and BTR. My car made 718rwhp and 638rwtq on a Dynacom dyno on pump 93. I would like to be cam only or heads and cam if the extra coin for the heads is worth it and run into the 9's on pump w/ no meth . I might consider using E85 if I have to upgrade my lowside which I'm trying to avoid, not because of cost just don't want to drill my tank. Can anyone that runs the BTR stage 2 give me some insight on numbers and drivability? Feel free to PM me if you like. I don't want to call MTI or RPM until I see some feedback on the BTR as I don't want to waste anyones time. Thanks
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's
sickss228 is offline   Reply With Quote
Old 10-20-2020, 07:11 PM   #2
newchevyman
Drives: 2017 Camero ZL1
Mine made 803 with similar mods and ported heads. Thread in my signature.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 10-21-2020, 06:45 AM   #3
Markoz28
Drives: 18 ZL1 nightfall grey A10
I have similar build but run meth. Car made 780/803 to the tire.
BTR is a great cam from what I have heard from friends and others. I have a Cammotion stage 3 and it’s awesome! It does buck a bit so I think going the stage 2 route would be much better for street manners.
I’m pretty sure BTR and Cammotion use the same grinds.
Markoz28 is offline   Reply With Quote
Old 10-21-2020, 07:19 AM   #4
IneedAZ
IneedAZ's Avatar
I thought you switched to the 2650?
Old 10-21-2020, 07:53 AM   #5
sickss228
Thanks for the reply, great numbers! Hows the drivability with the cam?
Old 10-21-2020, 07:55 AM   #6
sickss228
Strong numbers! Yes I think I remember hearing BTR gets his cams ground by Cammotion. Thanks
Old 10-21-2020, 07:58 AM   #7
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
My car made 677RWHP and ran a 10.10 in the Quarter mile, I would think you would be in the 9's already with 718RWHP?
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 10-21-2020, 08:00 AM   #8
IneedAZ
IneedAZ's Avatar
I too am doing a Stage 2 BTR. Hoping to get the car back in the next day or two.
Old 10-21-2020, 08:41 AM   #9
Juiced1
Drives: 2012 2SS CAMARO 45th
We've done the BTR stage 2 cam on several cars over here. Decent chop but not over the top. No drivability issues.
Juiced1 is offline   Reply With Quote
Old 10-21-2020, 09:14 AM   #10
newchevyman
Drives like stock. Just has some chop at red lights. Great all around cam.
2017 ZL1 A10
Old 10-21-2020, 09:52 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
All dynos read different and some tracks are faster then others. I have seen SBE NA H/C 6th gen SS cars run 9's @ 138 with 600whp. So variables like Less weight, good air, fast track(Atco) make a significant difference.
Old 10-21-2020, 11:10 AM   #12
Flowtie1
Drives: 2017 ZL1
The difference is in the 60' usually
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 10-22-2020, 06:29 AM   #13
wnta1ss
Drives: 2017 Camaro 1SS
Check out his sig line, he has an M6 transmission. Those have problems with the computer and most tuners don't seem to have the fix. Personally I have seen an M6 ZL1 on drag tires, modded up to 804rwhp, and frankly ET-wise it was way off what it should have done. The bog that GM has built in obviously ruins the party, and I think that it gets worse with more air going through the MAF.
Old 11-13-2020, 05:44 PM   #14
sickss228
Thanks for all the input guys. I ended up going with a MTI cam. I called and talked to Jayson and couldn't be happier with the customer service. I called a couple other shops and it seemed like they couldn't be bothered with my questions. I will try to make a thread that shows my build over the winter even though I don't know my way around a computer lol. I'll be doing the MTI cam, FED ported heads, CPR lowside fuel system w/ flexfuel, 2.3 upper pulley, BTR V2 trunnion upgrade, CPR bumper tank and the latest GM oil pump.
