Old 03-21-2020, 02:05 PM   #1
n12k1
Drives: V6 2LT Camaro Overkilled
Wiring diagram for the LED tail lights
Hi, is there someone who has a wiring diagram of the LED tail lights, which are used on the RS,SS and ZL1 models? On the plug i see 6 pins, I found out that there are two grounds, one positive for the reverse light, one for the brake/turn light and one for the actual tail light, but have no idea where does the 6th go.
n12k1 is offline   Reply With Quote
Old 03-21-2020, 02:23 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Here’s a thread discussing your topic. It may give you the answer you desire.
https://www.camaro6.com/forums/showthread.php?t=549679
Old 03-22-2020, 08:06 AM   #3
n12k1
The guy is having the same problem as I am, but the thread ends there.
Old 03-23-2020, 06:11 PM   #4
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
What problem are you having?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 03-24-2020, 10:29 AM   #5
n12k1
Well I wanted to have tail lights with yellow/orange turn signals, so i purchased EU version tail lights. But i didn't know that the EU camaro use the revese light as a turn signal and so the wiring is different for the US and EU models and now I get hyper flashing when i use the turn signals, even though my stock tail lights are LED.
https://drive.google.com/file/d/17C8...4fb83e5f2jsN8i
On the attached picture you can see one of the pins is missing on the new tail lights
Old 04-06-2020, 01:27 PM   #6
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
These are for a 2019, but they should be the same
Old 04-06-2020, 02:08 PM   #7
n12k1
Thanks for the response! I figured out that the problem is that on my new tail lights i am missing the "turn lamp feedback signal", which i have no idea how to simulate on the new lights.
Old 04-06-2020, 07:11 PM   #8
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Best guess is that you'll get a message that the lamp is out.
Old 08-12-2020, 06:17 AM   #9
Peter10654
Drives: Camaro 2SS 1LE 2019
You have to install a resistor to say the body control module everything is fine. Maybe the guys from gen5diy can help you
Peter
Peter10654 is offline   Reply With Quote
Old 08-16-2020, 06:34 PM   #10
Peter10654
Hey mate. Do you have maybe also wiring diagram from the reverse lights connector from the 2019 model? I need to build a custom harness and it would help to identify the type of connector.
Thanks
Peter
Old 08-17-2020, 06:56 AM   #11
n12k1
Peter
Contacted them but they had no clue about it
Old 08-17-2020, 12:46 PM   #12
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Thanks
Peter
They use the same connectors, x410 & x420, pin 4 for the signal. For European models one of them is the rear fog lamp
Hope this helps
Old 09-26-2020, 09:06 AM   #13
Peter10654
Hope this helps
Thanks mate,
yes I found it and could convert everything I need.
Thanks
Peter
Old 12-19-2020, 06:00 AM   #14
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Very useful, especially for European models that miss the side markers and the DRLs.
Do you or someone else have a similar diagram, but for the headlights? I am trying to figure out which wire in the headlight to tap into in order to fit aftermarket fog DRLs.
Thanks
