Old 03-11-2019, 11:40 AM   #1
raidaru
Drives: 2SS
what's the purpose of this wire?
All right, trying to figure out how tail lights work on camaro atm, the socket has 6 wires, 2 of them are ground, the other three : one is from drl, one from reverse and one for brake/turn signal. There is another one colour white/purple which I find no meaning to it, it has @11.7V on it all the time . This is on led tail lights. I also have @ a classic tail light, that one has only 5 wires socket but even there I see sth fishy, the brake/turn signal 7440 socket has 3 wires going in it, when the bulb actually needs only 2. Could anyone explain any of this?
raidaru is offline   Reply With Quote
Old 03-11-2019, 11:45 AM   #2
Peelam
Peelam's Avatar
Drives: 2016 Camaro 1SS, Jet Black, M6
Don't know for sure but my guess would be a signal wire to the ECU telling it if the lights are working or not.
2016 Camaro 1SS | M6 | Jet Black | Roto-Fab Dry w/SND Tube Delete | AWE Touring Cat-Back Exhaust
Peelam is offline   Reply With Quote
Old 03-11-2019, 11:47 AM   #3
shaffe
Drives: 21 Bronco
its for the optional rear facing machine guns haha
Lets keep it simple. ..
Old 03-11-2019, 04:58 PM   #4
Jeb114
Jeb114's Avatar
Drives: 2021 300
I believe its the control wire for the ECU. Monitors the condition of the Lighting system. The computer needs to know the status of the lights during operation.
Jeb114 is offline   Reply With Quote
Old 03-11-2019, 06:44 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
And why badly made aftermarket lights can and will and do drain your battery.
Old 03-11-2019, 06:44 PM   #6
ctrlz
Here are the pertinent schematics from the repair manual. If anyone can shed some light on the meaning of the symbols such as square, diamond, and circle with X, I would appreciate it!
Old 03-11-2019, 11:17 PM   #7
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
The circle X's are incandescent light symbols.
The diamond I think marks a managed voltage source. Like a dc-dc regulator
Old 03-12-2019, 02:55 AM   #8
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
Originally Posted by BuckeyeROC View Post
To conduct electricity.
Well, nobody can argue that on a very basic level you failed to answer the OP's question.
DC5 is offline   Reply With Quote
Old 03-12-2019, 02:56 AM   #9
raidaru
Drives: 2SS
It has nothing to do with the lights, the wire comes from ecu and has voltage on it without beeing connected to the tail light.
I still don't get where's that wire I'm talking about or what exactly it does. I'm trying to figure out a way to split the brake from turn signal without bringing wires from the engine bay, but probably that wire won't help much anyway....
Old 03-12-2019, 08:34 AM   #10
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
Inside the tail light housing there is another connector that connects to a circuit board that holds the leds. This might not shed light on your mystery wire but may give you something else to look at. Only thing is, to get to it the tail light housing has to be cut open. My project I have going myself is to kill the turn signal without any drawbacks (hyperflash, warning lights, etc.)
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 03-12-2019, 10:44 AM   #11
ctrlz
That wire is shown at the left of the first diagram as white with violet stripe. It appears to power the left stop/turn signal LED and the left stop lamp LED. I don't fully understand all the symbols on those schematics, but along the top the symbols do look like they might indicate steering column switch and foot pedal switch (based on my imagination).
EDIT: The symbol in the upper left which I thought might mean steering column is in fact a pull up resistor. The two symbols to the right are "high side drive switches" with the hand in the stop sign meaning "brake apply."
Old 03-13-2019, 02:57 AM   #12
raidaru
Drives: 2SS
Does anyone know exactly where is situated this body control module?
Old 03-13-2019, 02:16 PM   #13
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Look up under the dash where your stirring wheel is.
2SSRS@Gen5diy is offline   Reply With Quote
Old 03-13-2019, 02:23 PM   #14
2SSRS@Gen5diy
OP is your car a USA car or a euro car? if its a euro car need to know if its a LED tail lights or not? from there we can try to help, and on that socket with 3 wires but only needing 2 wire GM does that and runs the 3rd wire to the next socket, they do that to save weight, its called daisy chaining the wires.
