![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
JMS FuelMax installed
Would like to say thanks to TMS and XXX ZL1 for helping out with some details from their installs, I tried to make this as clean as possible. The following threads contain all the details you will need, I have some additional photos in mine, all 3 should be more than enough. This was done as a "no cut" installation, see parts list below.
https://www.camaro6.com/forums/showp...49&postcount=6 https://www.camaro6.com/forums/showthread.php?t=536723 Note: If you install the JMS FuelMax right near the plastic grommet you will not have to extend the cables, they just reach. The 30A fuse included is a micro fuse, you need to get a 30A micro2 fuse for the fuel pump. I mounted the FuelMax using industrial strength velcro so it could be easily accessed and gives it a little shock absorption. Parts required (from Mouser)
![]() Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
![]() Sent from my iPhone using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
![]() Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
Thanks a bunch for taking the time to post this. I am at the limit of my low side and need to install one of these. I DYI most of my mods so this is great.
Which JMS part number is the correct one for the ZL1? |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
Very nice! Turned out great. Here is the pic of how I set mine up. Should get really close.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
#7 |
JMS FuelMax worked out well. Was able to push into a smaller pulley with my setup finally. First pull we were rich up top and had more than commanded fuel pressure on low side initially (finally, was running down previously), high side was very stable. Car spent a bunch of time on the dyno and runs great. Tuning was done at Tune Time Performance.
#8 | |
![]() Drives: 2019 Camaro ZL1 Join Date: Jul 2019
I also have a JMS fuel max and its working great. XXX ZL1 is my buddy/tuner and we did them for the consistency on the pump. Also, for anyone that does these, you can use one of the spare fuse's in the front fuse panel if you forget to get a micro 30a. |
#9 | |
![]() Drives: Chevy corvette Join Date: Jun 2019
#10 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The JMS is a voltage booster that will feed your FSCM. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#11 |
#12 |
That is where I was landing prior to JMS FuelMax even though commanded was much higher. After installation we were able to achieve commanded on low side and the high side was much more stable.
#13 |
#14 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
sub'd for reference
| Tags |
| tms, xxx zl1 |
