Old 08-19-2018, 05:38 PM   #1
Jfmoore79
Jfmoore79's Avatar
Drives: 2016 Garnet Red 2SS A8
Fuel pump voltage booster install questions
In preparation for some mods this fall, those who have installed the JMS fuel pump voltage booster:
1. Where/how did you mount the unit in the trunk?
2. What route did you run the harness to the pedal?
Thanks!
Jfmoore79 is offline   Reply With Quote
Old 08-19-2018, 06:55 PM   #2
d729596
d729596's Avatar
Drives: 2016 SS Hyper Blue
Thanks!
For route of harness folded back seat down tucked it beside back seat then ran under trim of door sill. Mounted it on brace next to fpcm, drilled to small holes, brushed in a little primer to cover bare steel and used screws and nuts to secure it.
d729596 is offline   Reply With Quote
Old 08-19-2018, 08:58 PM   #3
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Here are some pics to help.
Location of booster- rear driver side quarter.
Harness to throttle pedal - use fish tape to route/pull through driver side rear rear side panel down to sill plate. Route under carpet along sill plate and under driver floorboard carpet to throttle pedal to make connection.
Power wires to FSCM. Drilled small hole through trunk floor plastic plug and routed wires down through to underside of vehicle to tap into FSCM.
Everything concealed after install.
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 08-19-2018, 09:08 PM   #4
Jfmoore79
Jfmoore79's Avatar
Thanks guys! Definitely some good ideas to consider.
Old 08-19-2018, 09:40 PM   #5
Jfmoore79
Jfmoore79's Avatar
Where exactly is the FSCM on these cars? When you came through the plug did you come back into the trunk again?
Old 08-19-2018, 10:24 PM   #6
TMS
TMS's Avatar
Next to the diff.
Once you route down to the underside of the car, that's it. You won't come back into the trunk again.
Old 08-19-2018, 10:32 PM   #7
TMS
TMS's Avatar
I should clarify my car is a 2018 ZL1.
Not sure if the FSCM is located in the same place as yours.
Old 10-05-2018, 09:35 AM   #8
Razor427
Drives: 2016 Camaro 1SS
I’m installing mine now... Which wire do you tap into???
Ray
Razor427 is offline   Reply With Quote
Old 10-05-2018, 09:49 AM   #9
L78toLT1
L78toLT1's Avatar
Ray
I'm planning on installing mine this afternoon. I got some instructions from Ted Jannetty that I can scan and send to you if you like. Instructions are at the house and I'm at work for a few more hours so I can't send them for a while. I seem to recall that the instructions were pretty thorough - several pages with color pics.
Baby Blue
Old 10-05-2018, 12:40 PM   #10
TMS
TMS's Avatar
Ray
Red with purple stripe. You can either cut and splice or de-pin so you can return to stock easily. Either way, the red wire from the JMS box goes to the red/purple wire before it enters the connector. The white JMS wire (shows yellow in my picture as I had to extend the white wire since it was too short) gets pinned/fed into the connector.
Old 10-07-2018, 03:28 PM   #11
Razor427
What wire do we tap at the gas pedal?
Ray
Old 10-07-2018, 07:28 PM   #12
TMS
TMS's Avatar
Ray
It's a plug and play harness. Nothing to tap.
Old 10-07-2018, 07:37 PM   #13
Razor427
I don’t have a plug on mine.... just a wire
Old 10-08-2018, 08:36 AM   #14
TMS
TMS's Avatar
Razor,
JMS has two versions. They have a vacuum reference version (with Hobbs switch) and a pedal position version. I am referencing the pedal position version that uses the TPS to trigger the voltage boost. Can you confirm which version you have? If you have the TPS version then the harness comes with a plug end that plugs into the drive-by-wire throttle pedal. Perhaps you have the vacuum reference version thus no pedal harness?
