Old 08-24-2019, 08:03 PM   #1
jmackisback
jmackisback's Avatar
Drives: 2019 Camaro ZL1
Exclamation 2019 ZL1.... rear 305/35/20 Nitto 555r?
As the title implies, I am wondering what the side effects of putting 305/35/20 Nitto 555r's on my 2019 ZL1 would be? I've read many threads but not come up with a clear answer. The only reason I want to put these on is because I have virtually new ones left over from my brief stint owning a Hellcat. Rubbing maybe? I don't really care about the speedo being out a couple MPH.
Thanks in advance for any input.
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
jmackisback is offline   Reply With Quote
Old 08-24-2019, 09:47 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
There’s a few of us running those rear tires on our stock SS wheels, so you definitely won’t have any problems on a ZL1.
Old 08-25-2019, 03:03 AM   #3
TEST DRyVer
TEST DRyVer's Avatar
Drives: 17 ZL1 6mt with PDR
I have asked 2 different wheel companies/distributors the same question. I was looking to run 285/35/20 in the front and 305/35/20 in the back for my ZL1. Both recommended against it... They stated the likelihood of rubbing on the inner wheel well plastics and wiring harness. Both recommended mild modifications in order to run a slightly higher series tire. Of course I've also read a couple of posts of people running them without problems. Some also believe that minimal rubbing is ok. I can tell you from a driving standpoint, rubbing of any kind ruins the handling dynamics of any car (with maybe the exception of mild rubbing at low speeds, when the wheel is locked in any given direction).
Anyway, for me, I just wanted more sidewall as I like a meatier tire. I will be taking their advice and not going to higher profile tires on 20's. However, it is making me consider running a different wheel with 285/35/19 in the front and 305/35/19 in the back. If I drop a wheel size, I can reduce weight, have increased ride quality, and run the higher profile tires that will likely result in slightly increased performance. I would be giving up the great 20' look on our cars...
Current Daily: 2017 ZL1 6mt in Black with PDR.
Esthetics: Nardo Grey wrap with original black accents throughout, complete Xpel ceramic coat, Diode Dynamics markers, Smoked GM tail & 3rd brake light, C7 Carbon 1LE style Spoiler in blk, ACS splash guards, blk'd out emblems. Variant Krypton wheels in Gloss black.
Performance: AWE Touring catback exhaust with resonator, Rotofab dry intake, TM throttle body, Kooks 1 7/8 Headers with Green Cats, Advanced Fuel Dynamics Flex Fuel kit with e50 blend and dyno tuned.
Current Family car (for the wifey): 2021 Audi SQ5
TEST DRyVer is offline   Reply With Quote
Old 08-25-2019, 09:55 AM   #4
jmackisback
Thanks for the input guys. Seems like the information is still conflicting.....hmmm
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 08-25-2019, 12:04 PM   #5
Joshinator99
Moderator
Not really...lol. KingLT1 has a good thread about it too.
Old 08-25-2019, 04:56 PM   #6
jmackisback
Question
So to clarify, you didn't have rubbing or issues with the wiring harness? For everyone who says they didn't, there is a person who says they did. Do ZL1s sit lower? What about the magride option?
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 08-25-2019, 05:14 PM   #7
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
On a M6 no rubbing. On the A10 the harness is there and will run through
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 08-25-2019, 06:04 PM   #8
Joshinator99
Moderator
No rubbing on either side. I proactively moved the driver’s side harness before putting the new tires on just to be safe. Takes about 4 minutes to move it over. Took me longer to find my bag of zip ties.
Old 08-25-2019, 08:29 PM   #9
jmackisback
Thanks, I feel better about putting these on now. I will move the harness as a precautionary measure.
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 08-25-2019, 08:52 PM   #10
Joshinator99
Moderator
No worries. Check out this thread too: https://www.camaro6.com/forums/showthread.php?t=541363
Old 08-26-2019, 04:57 PM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Josh is spot on. These tires are one of the best upgrades you can do to the car.
Old 08-26-2019, 06:09 PM   #12
DD goat
DD goat's Avatar
Drives: 2017 Hyper Blue Camaro 2SS
First of all, the harness you speak of on the drives side rear is on M6 cars also.
You'll have potential problems in the FRONT with the 285 35 20. Cars with mag ride (ZL1) don't like the clearance of the 35's in front
DD goat is offline   Reply With Quote
Old 08-28-2019, 09:54 AM   #13
jmackisback
Good information. Luckily I only want to put my old Hellcat 35s on the back.
1987 Camaro V6
1988 Camaro IROC Z
1993 Camaro Z28
1999 Camaro SS
2017 Camaro SS
Old 12-26-2025, 08:26 PM   #14
Aaronlunada@gmail.com
Drives: Chevrolet Camaro
I just put 305/35R20 Mickey Thompson ET on my rear 2023 ZL1 and they rubbed on the driver side inside fender. Something hard behind the wall. No go for stock wheels
Aaronlunada@gmail.com is offline   Reply With Quote
