305/35/20 Nitto 555r on stock wheels.
Put a set of these on my ride today. They fit the stock rear wheels great. Look good, handle fine, and they hook great. I was able to do a 1200rpm launch and pretty much dead hook on 47 degree roads. No wag like you tend to get with MT's either. On stock run flats I was spinning from a 40 roll in second. First try was a 3.8 0-60 with 30psi in the tires.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 03-12-2020 at 10:29 AM. |
Moderator
Well, looks like I know what my next set of rear tires will be then... great info, thanks for the pics too!
![]() Drives: SS1 convertible Join Date: Sep 2016
Are the wheels chrome plated? They look great!
Thanks!
They are PVD coated in a chrome finish. Kind of like a cross between Chrome and Polish... They won't pit or peel like Chrome plating. They do scratch but you can polish them out. Won't dull up like Polish. The PVD coating also doesn't add weight. Detroit wheel offers PVD in both black chrome and regular chrome. Forgot to mention in OP that I did relocate the harness on driver side rear since it's tight...super easy to do so no biggie.
Dropped them down to 28 psi and this was the result.
![]() Drives: '18 Camaro SS Join Date: Sep 2018
Looking good man. Love the way the 305/35/20 tires sit.
#7 |
Thanks! Me too...it really changed the look of the car.
#8 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I assume you had to move the wiring harness?
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#9 |
![]() Drives: 2017 Mosaic Black 2SS Join Date: Jul 2013
Looks good!! Gonna be my next purchase
#10 |
Yes..super easy to do. I replied in your thread about it.
Thank you sir!
#11 |
War Horse Pilot
Where is the wire harness relocation thread? My Google search didn't find it.
#12 |
https://www.camaro6.com/forums/showthread.php?t=485975
I will add that I would suggest poking a hole in the liner and adding a push clip to gain clearance so you don't rub through the liner as well. It's easy...there will be hole in the frame in the area where you see the liner has bee rubbed through in the picture. Poke a hole in that spot and use a push clip.
#13 |
Black lightning
Holyyyy craappppppp
[ 2021 Camaro ZLE 10 speed
#14 |
Black lightning
Where you launch at 2000rpm
