Old 03-19-2018, 06:42 PM   #1
VinceK
Drives: 2019 6.2L V8 SS
LACK of Wheel Spin?
Hey guys - I'm at kind of a loss here... I see plenty of posts, namely in the 0-60 thread, where people are talking about wheel spin and getting some pretty solid times with comparable mods to my own.
No matter what I do, be it floor it from a stop or build to 2500-2700, then let off the brake (A8) and hammer the gas - I cannot drum up even the slightest amount of wheel spin (I've tried with just TC off, and with TC + Stabilitrak off just to be thorough). It feels like the car is being extremely limited off of its launch, then can pick up pretty quickly after it gets going (consistent 5.4 with what feels like no power from the start).
Is anyone else having a similar issue? Or better yet, perhaps resolved a similar issue? I've tried to search for this among 6th gens, but came up dry. Any suggestions would be greatly appreciated. Thanks.
VinceK is offline   Reply With Quote
Old 03-19-2018, 06:51 PM   #2
6th_gen_gino
Drives: 2016 camaro 2.0t gray
I haven't heard of that issue before, it sounds like throttle cut but I don't believe our cars do that...I'd take traction all day over spinning tho
6th_gen_gino is offline   Reply With Quote
Old 03-19-2018, 07:05 PM   #3
VinceK
I hear you on taking traction... issue is it feels as if the power is cut out so much on the low-end of things that I am losing out on performance.
On maybe a slightly related note, did you guys receive a Stabilitrak error message when your vehicle was being tuned? I'm thinking they did not turn off the stabilitrak system prior to tuning, but curious if it just throws this every time we get on a dyno.
Old 03-19-2018, 07:16 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Torque management?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 03-19-2018, 07:26 PM   #5
VinceK
Originally Posted by danhr View Post
Torque management?
I thought about that, because I feel that the car was more aggressive pre-upgrades and tune in lower gears... but I didn't want to immediately point the finger at the tuner without getting some community input first. They are a particularly proud shop... but were very hesitant to take in my I4 and took a very long time to complete the tuning portion.
Any suggestions you have in particular on this front? Honestly I'm unsure how to tell them "something isn't right" other than saying it flat out, which will be met with lots of questions despite how sluggish the car feels in 1st gear.
Old 03-19-2018, 09:43 PM   #6
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Seems like you have a decent tune with your mods from your build thread. Probably exceeding limits. I would recommend removing the TCM and sending it to HP Tuners so they can "unlock" it. Modify the torque management, and slip % tables for each gear. You can not completely eliminate Torque management with out removing the engine management system altogether, but if you can find a happy place, understanding MOST decisions are based on TQ#'s reported by the ECM to the TCM, should eliminate your bog..
P.S. A lot of guys are Zeroing out slip tables and reporting a correction in the A8 shudder. Others are reporting if you wait too long, the TQ converter is too far gone, and even Zeroing out those tables won't correct the shudder.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-20-2018, 08:11 AM   #7
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Stabilitrak will almost always go off when getting off a dyno. I've been fortunate enough not to have that shudder some have experienced.
Old 03-20-2018, 11:09 AM   #8
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I don't see anywhere where you mention, or show pics of your car... Do you have the 18" wheels, or the 20" wheels? If you have the 20" wheels, they are pretty heavy. When I had the 20"s on my car, I would get like zero spin, despite on how high of an rpm I launched the car. Once I put some 18" wheels on (both with street tires, and my ghetto race tires), I could easily blow the tires off and had to actually try not to.
Old 03-20-2018, 02:17 PM   #9
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
I have 20" rims and I can roast them easily anytime I want to.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 03-20-2018, 05:29 PM   #10
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Same here....hooning advantage: M6
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 03-20-2018, 06:33 PM   #11
RedonBlackRS
Drives: 1LT RS 2.0T 8A HD
Hooning advantage is GM giving the manual an LSD and stealing it from people who paid extra for the auto lol
Yes, I'm still salty about that.
RedonBlackRS is offline   Reply With Quote
Old 03-20-2018, 09:16 PM   #12
cooper1965
Coopers Camaro
cooper1965's Avatar
I don't mind the lighter open diff in a straight line... Corners suck...
Old 03-20-2018, 09:38 PM   #13
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Try to do a burnout and see what happens
RobertAvitia is offline   Reply With Quote
Old 03-21-2018, 06:31 AM   #14
Corner carver
Lol, sorry man
