Old 05-20-2017, 06:53 PM   #1
Gutling
Drives: 2017 Chevrolet Camaro 2.0 LT
dual exhaust fascia swap?
I have a 2.0, with the single tips. I am going to do an exhaust eventually, most likely borla. Is it possible to remove the rear facsia and replace it with one from a ss, and then is it possible to use the ss borla catback with two tips instead of the 2.0? They look pretty identical in hangers and such except the two tips.
What would be needed, is the fascia just a single piece that comes off and can swap?
I tried searching, so if there is a thread please direct me to it and apologies.
Gutling is offline   Reply With Quote
Old 05-20-2017, 06:57 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Yes, single piece..... you can swap fascia, needs to be painted.
Old 05-20-2017, 07:03 PM   #3
Gutling
Mine is unpainted plastic, and I am meaning the piece around the exhaust tips not the whole rear bumper.
Old 05-20-2017, 07:06 PM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I know what you mean, this lower plastic can be swapped to quad tips.
Old 05-21-2017, 09:16 AM   #5
Stewhoppy
Drives: 2016 Camaro SS
I am also going to do this on my SS but going to try cutting the rear panel!
Has anyone else tried this? Will then probably get the panel wrapped in cf.
Stewhoppy is offline   Reply With Quote
Old 05-21-2017, 09:54 AM   #6
wrankin
Camaros Of Northwest Ohio
Drives: 2023 Red Hot 2SS 1LE
The dealer said the whole rear bumper cover needs to come off to change the facia. I had some damage from an incident the previous owner had, and was looking for the easy way out and just to do a swap of the facia. I ended up having the dealership do it, and it's a good thing as the crush bar behind the rear cover had damage too
Bill R.
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 05-21-2017, 10:19 AM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
you can get the fascia off with bumper intact. Someone put pics here....
Old 05-22-2017, 05:29 PM   #8
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
Check here on how to remove...
http://www.camaro6.com/forums/showthread.php?t=477187
pjz1082 is offline   Reply With Quote
Old 05-23-2017, 03:48 PM   #9
Gutling
Thanks everyone. Yeah my last car had dual dual tips and I really liked the look. The single just looks so small on the big rear end.
Old 05-24-2017, 09:09 AM   #10
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Mishimoto had a 4 tip exhaust specifically engineered for the 2.0... It's on presale now
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 05-24-2017, 12:01 PM   #11
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Originally Posted by pjz1082 View Post
I would now recommend this procedure, as you can seriously damage the facia in the middle area, as you don't have access to those three/four metal clips holding the part to the main bumper cover.
The safest way is to follow the dealer's instructions: the main bumper cover must be removed in order to have a comfortable and safe access to all metal clips/retainers that are right behind what is clearly visible.
I've done it in order to have my facia painted, as you can see here:
http://www.camaro6.com/forums/showthread.php?t=490528
See you!!,
Eos
Eos is offline   Reply With Quote
Old 05-24-2017, 12:31 PM   #12
Gutling
Thanks for the heads up on the mishimoto exhaust, that would be perfect then just need the fascia.
And thanks Eos, I was looking at a removal of it that showed those clips in the middle. Is that a reverse light on your diffuser? Is that stock on certain trims/packages
Old 05-24-2017, 03:36 PM   #13
Eos
Eos's Avatar
Hi Gutling!!,
Yes, that raw of LED lights looking like a smile on my car's bumper are specific to the European version of the Camaro: it contains the reverse LED lights and the fog lights. Turn lights on European cars are built in the main lamp, where you have now the reverse lights, separated from the main rear lights (red & stop lights).
Please post some pictures of what you will be doing to your car..
See you!!,
Eos
Old 05-24-2017, 06:42 PM   #14
pjz1082
pjz1082's Avatar
See you!!,
Eos
Just letting him know it can be done. Everyone has their own opinion on things. Taking a dealers word doesn't mean squat to most, no offense. And personally, if I'm removing that factory fascia, I'm tossing it in the trash so it wouldn't matter. But that's just me.
