Old 12-15-2016, 12:36 PM   #1
viewska
Drives: Red Hot Vert
Post DIY: Rear fascia removal
The job is fairly simple, but I always like to know what I'm in for before beginning any project. I didn't find one here so I figured I would write one as reference point for anybody interested in this. 10-15min
Tools:
7mm socket
T-15 torx
Long screwdriver (or a plastic putty knife could also do the trick)
1. On either side of the fascia there are 4x 7mm bolts and 2x T-15 torx readily visible and can be quickly removed.
2. Looking underneath you will spot another 2x 7mm
3. Now, this little hidden bolt on the inside of the bumper/fascia assembly is the reason i decided to do a write up. There is one 7mm bolt per side and you need really work with this one. I recommend just letting your hand cramp and working through the pain
I would say its roughly about here:
4. With all the 7mm bolts removed the rest of the job is decently quick. There are 4x bumper-tabs per side that can be pulled away from the fascia pretty quick and easy
5. Starting on either side with all bumper-tabs removed for that side you can access and remove the first (largest) fascia-tab. The first one has a metal retainer clip in place so it is a little stronger than the others. I was able to reach behind and wiggle mine until it popped free. Repeat for other side.
6. The method i used which seemed to work with little to no damage to anything was to work on the outsides inward by releasing one fascia-tab at a time. Pulling the fascia away from the bumper creating enough space/tension to touch the clippy part of the fascia-tab to pop free
7. There are three more of those metal retainer clips dead center, no way to access them, no tabs or anything I just pulled and they popped free.
Here is a bonus view of those reflectors. one single Phillips screw each side for removal
viewska is offline   Reply With Quote
Old 12-15-2016, 01:10 PM   #2
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
Thank you! this is so helpful!
keysersoze is offline   Reply With Quote
Old 12-16-2016, 12:17 AM   #3
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Sure is thanks!!
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 12-16-2016, 08:32 AM   #4
motorheadkev
motorheadkev's Avatar
Drives: 2017 Camaro 2LT-217CI
7mm bolts
interesting observation that Chevy uses 7mm bolts to hold items on car.
years ago they were 10mm bolts.
so reducing bolt sizes reduces weight.
very smart, and im sure all bolt sizes were reduced. nice, every little bit counts.
motorheadkev is offline   Reply With Quote
Old 12-16-2016, 05:50 PM   #5
CMCamaro
CMCamaro's Avatar
Drives: 2022 Silverado, 3.0 diesel
Very helpful Viewska!
CMCamaro is offline   Reply With Quote
Old 12-21-2016, 12:55 PM   #6
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
Was the purpose of the removal to take out the reflectors? If so, can you not get to them without removing the entire fascia?
pjz1082 is offline   Reply With Quote
Old 12-21-2016, 05:20 PM   #7
sureshshanmugam79
sureshshanmugam79's Avatar
Drives: Summit White 1LT RS I4 M6
Very helpful... thanks much. I always wanted to have it painted gloss black and this article is very helpful.
2016 1LT RS Summit White M6
10/2/2016 - 3 Miles on ODO - Delivered
11/1/2016 - All around light Black out kit from Phastek
11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com
12/16/16 - 977 Miles. Borla S-type Axleback
Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED
sureshshanmugam79 is offline   Reply With Quote
Old 12-21-2016, 05:33 PM   #8
cellsafemode
cellsafemode's Avatar
Wouldn't this be the same for any non-npp camaro?
not sure what about it is V6 specific.
Old 12-22-2016, 06:49 AM   #9
viewska
Yes, I guess it isn't trim specific, I just posted it in here, maybe a mod can move it to where it needs to be
Old 12-29-2016, 11:11 AM   #10
jrobinson1016
Drives: 2016 Camaro 1LT RS Hyper Blue
This was definitely very helpful. I changed mine out last night, and I would say it took around 4 hours to fully complete. I was probably being overly cautious and wasn't really in a rush. Now to decide what quad tip exhaust to go with.
jrobinson1016 is offline   Reply With Quote
