Old 03-28-2017, 05:11 PM   #1
parish8
Drives: 17 SS a8
bmr rear suspension parts ?
I want to run 8's some day. I currently need at minimum toe rods and cradle lock out. I am wondering what other parts I should install while I am in there to prepare for my end goal.
I don't want to buy parts that will increase noise and vibration if they are not needed but will live with it if I have to.
do I need to buy upper trailing arms? if so non adjustable or single adjustable?
do I need to buy lower trailing arms? if so non adjustable or single adjustable?
do I need to buy upper control arms? if so non adjustable or single adjustable?
are there other parts I should consider buying while I am there?
Old 03-28-2017, 05:29 PM   #2
BMR Tech
BMR Tech's Avatar
For the power levels and stress that car will be seeing, I would highly recommend going with all of those components in adjustable form. The decision would come down to you for on car versus single adjustable. They will only create a slight increase in NVH, but the strength and traction they provide will more than make up for it. The toe rods and cradle lockout will complete the puzzle back there.
I can put you together a package deal on all of these components and save you a little money and ensure you are getting the best parts for your combo
BMR Tech is offline   Reply With Quote
Old 03-28-2017, 08:30 PM   #3
parish8
Drives: 17 SS a8
pm sent
Old 03-29-2017, 07:10 AM   #4
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
I'd be interested in your recommendations for a 1LT...
I'm in the same boat as parish8 (just way less power)
I would like to button down the rear end as much as practical without greatly increasing NVH.
Car is a daily driver first, but will eventually see around 600hp and some stickier (not slicks) summer tyres.
Will be also used for HPDE days and the 1320.
Thank you!
*edit* I find the rear end is 'sloppy' even at the stock power level.
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 03-30-2017, 04:39 PM   #5
Mr. Rager
Drives: 2017 2SS MRC NPP
I think the rear is way too busy at stock power as well. Even a stock SS will drive over the top of the tires at lower speeds and hard throttle. Getting a 4.0s 0-60 is a hail mary and everything has to go just exactly right, even when it happens i can tell the car pulls power. Aside from that the rear stepping out to the right at the hit is a bunch of crap.
I think i'm going to do the links aside from the toe links since I don't want to jack with the alignment if i can avoid it. Going all fixed length since mine is a daily driver. Also doing the bushing lockout kit, might start there and work my way out so I can see how it responds and decide where to quit. Hopefully don't need to go cradle braces etc at stock power.
Also doing the 1LE sways, since a bigger bar used to help with the rear on my older cars plus its super cheap if you have MRC $165.
Basically on a quest to be able to use all the stock power, even if it means a drag radial. Once I get there I will add some more.
2017 - Black - Silverado 1500 Crew Cab - LTZ
4x4 - 5.3 - 6spd - 3.42 - black leather
Sold 8/31/2017 2017 - Silver Ice Metallic - 2SS
A8 - MRC - NPP - black leather
1996 - Sebring Silver - Trans Am - WS6
383cid - Ported heads - Bullet Cam - 4l60e - Yank SS4000 - 3.90 gears - Kor3 Brakes
Built and tuned by me 445rwhp @ 6400rpm - 11.4 @ 122mph
Collecting parts for 408 LS3 and 500rwhp.
Mr. Rager is offline   Reply With Quote
Old 04-04-2017, 02:32 PM   #6
Corner carver
even pulling a 5.0 0-60 with the turbo the rear end is squirming around... I won't be adding more power or stickier tires untill its quelled down a bit.
Old 04-05-2017, 04:07 AM   #7
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Get lower and upper trailing arms should get rid of your issue.
