Old 01-09-2016, 01:46 PM   #1
MrImSoFly
MrImSoFly's Avatar
Drives: 2017 Hyper Blue 2SS
Clinking noise has surfaced.
Took the car in this morning. Started hearing a clicking noise from the front passenger side. Techs couldn't diagnose the issue so they gave me a rental. Told me to check back at the end of the day. Hope to have the car fixed by Monday.
MrImSoFly is offline   Reply With Quote
Old 01-11-2016, 03:35 PM   #2
MrImSoFly
MrImSoFly's Avatar
Apparently there was an issue with the steering gear and the part had to be order from the factory in lansing. Expect to have an update on the vehicle Wednesday.
Old 01-11-2016, 04:22 PM   #3
SSport16
SSport16's Avatar
Well that's good they found the issue, hopefully that resolves it.
Old 01-11-2016, 04:37 PM   #4
ussj4brolli
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT
I need to drive without my damn music full blast once in a while... not "hearing" this could of caused some damage later on...maybe severe.
ussj4brolli is offline   Reply With Quote
Old 01-11-2016, 04:48 PM   #5
MrImSoFly
MrImSoFly's Avatar
Yes it could save you some money down the road lol. I just so happen to have the radio down because i was talking and actually heard it.
Old 01-11-2016, 05:49 PM   #6
ussj4brolli
Well we do have 5 years. This could be BAD. "take that left turn" SNAP....car goes FWD....
Old 01-13-2016, 01:27 PM   #7
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
Could you describe the clicking noise better? Mine seems to be coming from the back passenger side, but maybe I'm just hearing it wrong. Is it intermittent or consistent? Does it vary by speed? I've seen some posts where others experienced it but it was related to either something stuck in the tire or the NPP valves. I normally don't hear these things either with my music playing.
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
Old 01-13-2016, 01:38 PM   #8
MrImSoFly
MrImSoFly's Avatar
It happened when ever i went over a bump or when i turned the steering wheel. They actually diagnose the problem as a steering issue with the rack and pinion. I had a slight feeling this would be a problem because the vehicle could not drive without slightly going left or right. once they fix the issue and do an alignment i should be fine. my only worry is how the new the car is and the lack of experience with this specific model.
Old 01-13-2016, 01:45 PM   #9
NY Andrew
NY Andrew's Avatar
Thank you for clarifying all that! I should be good then, but have noticed the ride is a little more bumpy/shakey than it was when I first drove it, but apparently it's nothing they were finding..a rebalance did help though. Besides that only other issues I have is the occasional click and the stutter at low RPM in between gear, but guess those seem to be normal as well. Hope you get it back soon and it's working how it should! Check to make sure they did a software update as well to save yourself a trip going back.
Old 01-13-2016, 02:33 PM   #10
MrImSoFly
MrImSoFly's Avatar
Thanks for the heads up on the software update. I will let them know that for sure.
Old 01-14-2016, 09:07 PM   #11
asimpleguy
asimpleguy's Avatar
Lately I have really been noticing my car slightly shuttering or shaking when the AFM kicks in on the highway. Everytime i push on the gas and the AFM turns off, the car stops shaking. I'm planning on taking it in soon and hopefully they can figure it out. Is this the same thing you've been experiencing NY Andrew?
asimpleguy is offline   Reply With Quote
Old 01-20-2016, 05:20 PM   #12
NY Andrew
NY Andrew's Avatar
Mine seems to have gotten a little better, maybe it needs more break-in (I'm over 3200 miles), but I still notice it nonetheless. Here's my post about it:
http://www.camaro6.com/forums/showthread.php?t=435467
Definitely keep us updated if you bring it in!
Old 01-21-2016, 12:17 PM   #13
MrImSoFly
MrImSoFly's Avatar
I received my camaro back from the dealership on Monday. It seems to be running smooth as of right now. For my troubles GM has offered to extend my bumper to bumper warranty to 4 years or 60,000 miles.
Old 01-27-2016, 08:17 AM   #14
dlions20
Drives: cobalt
I'm having this same issue I think.
Whenever going over bumps , I hear this metal clinging noise.
Is that what you were getting?
dlions20 is offline   Reply With Quote
