07-27-2020, 05:59 PM | #1 |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
Rear wheel well liner wear... track induced?
Hey guys, figured this question would be good for the lowered crowd.
TLDR: do you think this wear is from a few runs down the corkscrew or maybe an ongoing issue? Took my wheels off and noticed the left rear fender/wheel well liner had a wear spot about a centimeter or so and a wiring harness is poking through and slightly worn too. I am stock wheels/height/everything SS1LE. I was at a few tracks with the car (Sonoma, thunderhill and Laguna Seca) and there is a high load area at the bottom of the corkscrew that is top of my ofFENDER list (dad joke). I don’t remember ever hearing any scraping or anything but here’s a couple photos of the damage and one of the car under load. I won’t be going back to Laguna for a long time but I’m not sure how to know if this is an ongoing issue or not and I don’t want to destroy that harness (which doesn’t have much room to be re-routed). I searched and didn’t find any similar posts. Thanks for any input! |
07-28-2020, 07:01 AM | #3 |
That's an uncommon wear spot on an otherwise stock 1LE, usually only a factor if some one goes with a 305/35 or larger tire. Easy reroute of the harness though.
07-28-2020, 08:00 AM | #4 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
It's interesting: a friend and I both bought brand new 2020 SS 1LEs this spring, and we both autocross them. He had wear through the liner and I haven't, and the only difference I know of is that he attended one track day with his and I haven't yet. This is all on the original-equipment wheels and tires. Hmmm.
Matt Miller
2020 SS 1LE |
07-28-2020, 09:42 AM | #5 |
Now by the photo those track conditions you car does appear to be low enough that I went back and read the OP a few times about being stock probably a track induced situational rub given the conditions you're getting.
07-28-2020, 03:07 PM | #6 |
I'd just relocate the harness and call it a day, all it takes is about 5 minutes and maybe an extra zip tie (https://www.camaro6.com/forums/showthread.php?t=485975).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 07-28-2020 at 11:25 PM. Reason: typo fix (because OCD) |
07-28-2020, 05:32 PM | #7 |
The harness should of never been routed that way from the factory...another GM blooper.
2016 NFG 1SS A8
07-28-2020, 07:13 PM | #8 | |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2020
They found left rear inner liner with hole and worn through wiring harness. They said harness had not been secured properly at factory. The clamp barb had not been inserted in hole, allowing harness to push against liner, which pushed against tire. I’m not sure I believe the harness could create this much force to push the liner against the tire, but it might be worth looking to see if it has been properly secured before doing a track event. |
07-28-2020, 09:24 PM | #9 |
Great response everyone. Sorry I didn’t catch sledgehammer’s post about it. Guess I’ll go the zip tie reroute route ... weird situation but seems like i caught it before any real damage was done.
Thanks again! |
08-02-2020, 09:32 AM | #10 |
One thing occurred to me as I was replying in a different thread: with the semi-trailing arm architecture of the rear suspension, pushing the lateral lower control arm outward to get more negative camber would also move the knuckle forward a bit. So this rubbing is more likely to happen to cars that have maximized rear negative camber. Not that this should be an issue on a car with stock tire sizes. But if you also have a harness that's not properly clamped to its bracket (a la post #8) and it wedges in there so as to push the liner out a bit, and you have maxed out your negative camber, things could get a little too close.
Matt Miller
2020 SS 1LE |
08-02-2020, 10:04 AM | #11 |
Drives: 2018 ZL1 1LE #928 Join Date: Sep 2013
Found holes in three out of four inner fender liners
Someone out there should offer aftermarket plastic liners |
08-02-2020, 02:52 PM | #12 | |
08-02-2020, 08:16 PM | #13 |
Drives: '19 Camaro ZL1 A10 Riverside Blue Join Date: Feb 2020
this may give you more info, it came out a few months back.
https://gm-techlink.com/?p=13197 i posted it yesterday over in the zl 1 section, https://www.camaro6.com/forums/showthread.php?t=579402
