Old 07-29-2020, 07:09 PM   #1
Swift016
Swift016's Avatar
Drives: 2019 ZL1 1LE
Fuel leak !!!!
Guys,
2019 ZL1 1LE.... pulled out of my garage with 3/8 tank of fuel ⛽️ and 120 miles to empty. After 1 mile I looked and it showed 1/4 tank and 70 miles til empty...
I woke up to that ! I watched as the gas needle visibly was decreasing and the trip computer was constantly decreasing the miles to empty.
I drove one more mile and stopped at a safe place just as the low fuel alarm came on and the gauge showed E...
I shut off the engine immediately , but it never ran rough or entered a Limp Mode.... it was raining hard so I couldnt see any visible leaks.. Towed to a dealer, but they were already closed.
My best guess is a big leak in one of the pressure lines , rail, or injector, but the engine never ran rough, so I’m uncertain.
Anyone see anything like this, or have a better guess.....no way a fuel gauge would fail in this way...
Thanks guys,
Bill
Newnan, Ga
Swift016 is offline   Reply With Quote
Old 07-29-2020, 07:41 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Good luck Bill!
Old 07-30-2020, 12:34 PM   #3
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Any update on this, your car is stock right? A fuel leak like that should create a strong fuel smell at the leak point and everywhere it goes making it easier to locate. At least no fire, so that's good.
SFV1LE is offline   Reply With Quote
Old 07-31-2020, 07:12 AM   #4
Swift016
Swift016's Avatar
Mystery solved....
It looked exactly like a pressurized leak.. Heavy rain would have masked the smell.... But, no Leak. It was all electrical , but did not look like any gauge failure I have ever seen.
The left rear tire cut through 4 wires in a bundle. The dealer repaired the wires and rerouted the bundle.
Take-away :
Dealer notified GM of problem area
Dealer looked for larger than OEM tires to disallow the warranty repair. Mine were OEM size...
Next time you have the left rear off, take a look and have your dealer do a warranty repair... I can send a copy of my repair invoice if anyone needs it.
Cheers,
Bill
Old 07-31-2020, 08:57 AM   #5
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Thanks for the update, what side is the harness on? Would like to take a look.
pauly1119 is offline   Reply With Quote
Old 07-31-2020, 09:42 AM   #6
ZL1 affair
ZL1 affair's Avatar
Drives: 1of 66 Orange Crush 2020 ZL1’s
Are you serious?
Dreaming of a 2020 A10Crush ZL1 *TPW Sept 30* Built November 14, 2019, shipped Nov 15, 2019. Arrived at the dealer January 29, 2020.
2013 CTSV coupe 6MT SOLD
ZL1 affair is offline   Reply With Quote
Old 07-31-2020, 09:44 AM   #7
ZL1 affair
ZL1 affair's Avatar
Originally Posted by Swift016 View Post
Mystery solved....
Take-away :
Cheers,
Bill
Thanks for the update. I just had my wheels off of my 20 ZL1 and didn't really notice anything. Might have to pull my LEFT REAR WHEEL off to have another look.
Old 07-31-2020, 09:48 AM   #8
Swift016
Swift016's Avatar
Lol ! 😊
Old 07-31-2020, 09:59 AM   #9
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
Mystery solved....
Take-away :
Cheers,
Bill
Thanks for the heads up!
Are you looking at the car form the rear or front when you say left rear wheel? J/K
minn19 is offline   Reply With Quote
Old 07-31-2020, 10:38 AM   #10
ember1205
Hot Camaro
ember1205's Avatar
Which left rear wheel, though? The one up front? Or the one on the passenger side?
Old 07-31-2020, 01:11 PM   #11
Rnovrit
Drives: 2018 NFG ZL1-1LE
I think what you are asking is where is the harness in the wheel well? Or maybe your just having one of those days. LOL! Forward side of wheel well towards the center of the car. There is a main harness routed along the inside of the wheel well liner. Sometimes wider tires will rub there and damage the harness. On rare occasions, sometimes the harness is not correctly positioned and pushes the liner out causing a rubbing issue. Here is a pic I found posted by someone else to help with a visual.
Rnovrit is offline   Reply With Quote
Old 07-31-2020, 04:59 PM   #12
SFV1LE
That's good news about fuel leak. Very weird the stock rear 325/30/19 ZLE 3Rs did this. Your wiring harness must have been bunched up or routed weird, and sticking out a LOT more.
I was running 345/30/19 PSC2, 135-140 mph on Nascar banking turn 1-2 at Auto Club Speedway, and only light rubbing with small hole in liner and no damage to harness. I re-routed.
Old 07-31-2020, 09:46 PM   #13
JD64
JD64's Avatar
Drives: '19 Camaro ZL1 A10 Riverside Blue
here is a little more info. https://gm-techlink.com/?p=13197
JD64 is offline   Reply With Quote
Old 07-31-2020, 11:47 PM   #14
Ants.ZL1
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO
I just got some slicks for my car and when I was installing them and checking clearance I noticed that it was rubbing the inner fender liner on the driver's side so I pulled the liner back and found the fuel pump harness was holding the liner out and causing it to rub the tire. I assumed that this was because of the size of my slicks, I moved the wiring and then added a clip to hold the liner in. Now that I see your issue I think its a flaw in the routing of the harness. Glad I noticed mine before I had and issue!! Also happy they fixed yours.
Ant
Ants.ZL1 is offline   Reply With Quote
