Relocating Wire Harness for Larger Tires
Someone asked for a summary of how to do the wire harness relocation for the driver side rear wheel well when upgrading to larger tires. I uploaded this summary and picture and figured I would share here:
Here's a picture of my driver side rear wheel well. After you remove the wheel well liner you should see a cable that runs in the general path of the red line. - Remove the wheel well liner by popping out the handful of plastic clips (I only undid the forward half of the liner) - The yellow marks represent where the cable is secured with a zip tie, - Cut the bottom 2 that are shown - Relocate the cable by sliding it inboard as far as it goes (shown by the green line) - Down at the bottom by the harness connector you will see a frame with a hole that you can run a zip tie through to secure it in it's new location You can see in the picture where the hole will form from rubbing. This particular picture is from a BFG 305/35/20 on stock springs. Why did I go with a 35 instead of a 30... Because that's all the BFG comp 2 A/S comes in and I wanted to run a 305 size A/S on my 20x11s. After a few hundred miles the rubbing stopped (didn't get any bigger than what you see below) and no issues with damage to the cable. |
![]() Drives: 2018 Camaro ZL1 Join Date: Jul 2016
Thanks for the write up and Pic!!!!
![]() ![]() ![]() ![]() Drives: CAMARO Join Date: Jan 2017
Perfect!!!!
Thanks JATT |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Going to wide for track lol. I had to rerouute the wire today
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#7 |
#8 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
How wide did you go?
#9 |
![]() Drives: 2017 Camaro SS 1LE HBM Join Date: Feb 2017
Is this already done at the factory for 1LE SS ?
Mr Al |
#10 |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 A10 Join Date: May 2012
Hmmm...was this changed for the 2018 ZL1?
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
#11 |
Chin Event Manager
Drives: 2018 SS 1LE Join Date: Dec 2011
I'm gonna say no because mine is wearing through the liner right at that spot and i't completely stock.
Jim Pomroy
Chin Track Days Chief Instructor and Event Manager 2018 1LE 2015 Mustang GTPP 2011 Duramax Access to several Chin track cars... |
#12 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Just relocated mine last night before mounting 305/45/17 Mickeys for the track.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#13 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
I took my wheel off and did the wire reloaction as directed above. Then I went down to discount tire, after a sweet burnout of course, and had some ps4's installed. (295 in the back)Upon receiving the car, discount tire said it was rubbing the fender well a little bit. So I went home, pulled off my tire and peeled the liner back, cleaned a couple spots on the frame with alcohol, and stuck velcro to the car, then peeled the other side and stuck it to it. I then put the liner back and pressed where the velcro was. I gained maybe an inch of space as there was a gap between the liner and the car. I can now get my fingers behind the tire where before I couldn't. Figured this might help some people from preventing holes in their liner.
#14 |
![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
No. Had to relocate mine. It’s simple.
