Old 04-12-2017, 12:20 AM   #57
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Originally Posted by glamcem View Post
This has been originally discussed at this thread :
http://www.camaro6.com/forums/showthread.php?t=487290
and then another forum member mentioned here:
http://www.camaro6.com/forums/showthread.php?t=488500
I ran into the same issue after my second track day. I initially thought that I had bad fuel and since I couldn't reset my ECM (apparently not easy task on these cars), I was under the impression that the ECM cannot recover itself from the bad/low octane map or pulling timing or something (as it did with previous Gen Camaros).
I've scheduled an appointment with my dealer for this Wednesday to do that. It's also a bit hard to replicate the issue on rainy, cold days since it requires a WOT and can only be done (safely) in traffic on 2nd gear.
I was scratching my head because it happened to a 17 Camaro SS owner, a brand new 1LE at the dealer showroom(!), to my 17 1LE and a 17 ZL1 owner. I would understand the SS cars but ZL1 has a completely different motor and a tune of course. Forum member "geaux_tigerss" says that the dealer replaced the camshaft solenoid and ECM but still didn't fix the issue . It turns out that the A/C belt -under high load- was rubbing against the wiring harness right below it, and stripping two wires and causing that surging issue at around 5500 RPM. It didn't reach to a point where it displays a CEL in my experience but he had both CEL and the issue was existent all the time.
I checked mine and as expected I was dealing with the same exact issue. I took some pictures showing how it's stripped. It looks like a manufacturing defect and somehow they didn't pay attention to that clearance between the wiring harness and the A/C belt. I would be surprised if the clearance is different on other cars unless they changed the method of putting the wiring harnesses all together. I would highly advise to check yours and if you don't see any rubbing/stripped wire, consider yourself lucky and simply put a zip tie to make some space between those two (wires and A/C belt above it)
I put the below pieces aside for an easy access:
Notice the two completely stripped wires touching each other in the below picture.. right next to the purple wire:
I used some electrical tape to insulate those two wires (simply pushed some tape with a thin, flathead in between) then wrap around it with another electrical tape and zip tied it with the connector wire so that it would pust it away from the belt and give some space.
Note: Needle nose pliers helps a lot if you have big hands like me
I took it for a quick ride to test it and the hesitation is gone now. Phew! what I relieve ..
Great thread here, would you be cool if I made a video to alert other Camaro friends, at least getting them to check their cars to see if they are seeing this issue? I'll of course give all credit to you and link back to this thread. Shoot me a DM if you're cool with it.
Sledgehammer70 is offline   Reply With Quote
Old 04-12-2017, 01:08 AM   #58
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
Geeze, that's a really crappy design. "Lets put some wiring harnesses right next to a moving belt driven system." Engineering skills. :/
I hope they issue a recall for you guys, even if its something as minor as adding a zip tie to move it slightly. Still, that must be kind of unnerving if it were to ever shift around, plus the general fact that if you ever needed the engine serviced, a mechanic could end up undoing the fix very easily.
RenegadeXR is offline   Reply With Quote
Old 04-12-2017, 02:55 AM   #59
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by devnull View Post
12/16 SS 1LE here. Probably have an inch or so of room between that belt and the wires. GOOD CATCH glamcem!!!
PM sent
I have to mention though there are so many owners with no issues but it's definitely worth checking
glamcem is offline   Reply With Quote
Old 04-12-2017, 07:23 AM   #60
Sub
Sub's Avatar
Drives: 2017 ZL1
Thanks for the info
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 04-12-2017, 08:02 AM   #61
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
May just be the angle, but it looks closer than an inch? (the blue and yellow wires and such)
Old 04-12-2017, 08:03 AM   #62
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
A video would be great fellas...as it would be able to show exactly where this harness is from multiple views. Some may need that...
Old 04-12-2017, 08:29 AM   #63
KS1LE
KS1LE's Avatar
Drives: 17 SS 1LE, 02 GTP
Thanks, I'll check mine tonight!
2017 Mosaic Black Metallic 1LE
KS1LE is offline   Reply With Quote
Old 04-12-2017, 09:14 AM   #64
ctrlz
Looks like 3 wires:
Purple, Blue, and yellow/black
That would work for a Hall effect sensor which has:
1) Signal
2) Signal ground
3) reference voltage
Old 04-12-2017, 12:32 PM   #65
FlashBang23
FlashBang23's Avatar
Drives: 2017 1LE
Well my car was throwing codes P0011, and P2088. Took it to the dealer to read the codes, then sent pics of them to @slick3. He sent me this thread and what do you know....my belt was rubbing as well. Currently trying to contact the dealer to get a resolution in place.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
FlashBang23 is offline   Reply With Quote
Old 04-12-2017, 12:51 PM   #66
ctrlz
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P2088 - "A" Camshaft Position Actuator Control Circuit Low Bank 1
Originally Posted by ctrlz View Post
I am changing my guess to crankshaft position sensor.
Should've stuck with my first guess!
Old 04-12-2017, 01:10 PM   #67
JFM-jr
JFM-jr's Avatar
FWIW to this thread I checked my 16 SS A8 and this wire is nowhere near the belt.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-12-2017, 03:02 PM   #68
FlashBang23
Drives: 2017 1LE
Yep lol. The service advisor started reading the codes and i was like oh no (my G8 had some electrical issues that forced me to trade the car in). Thankfully I was able to assess the real cause. They probably would've replaced the solenoid (p2088) and then tried to figure out what else was wrong.
Old 04-12-2017, 03:13 PM   #69
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Well... guess I know what I'm doing tonight
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 04-12-2017, 04:05 PM   #70
glamcem
glamcem's Avatar
all good info, thanks everyone
I wish I didn't forget to add a poll to the OP so we would be able to tell how frequent is this issue.
