Old 03-21-2017, 12:36 PM   #1
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
Surging at high RPMs
My car is a 2017 2SS M6. 100% stock, no performance mods.
I've noticed at high RPMs and WOT it surges 1-2 times. Usually at around 5200 and 6000 or so RPMs. This happens in 2nd and 3rd every single time at those RPMs and WOT. It almost feels like pulled timing, but it's very short duration (fractions of a second) and the power comes right back. When it does it in first gear I assume its due to traction control since that light pops up every once in a while. I highly doubt traction is the issue in 2nd gear, and no way the tires are getting loose in 3rd on a straight and 80* temps. It does it in tour, sport, and track modes regardless of whether ARM is enabled.
Anyone else notice this? I really dread having to bring it to the dealer and have some random tech beat on it to replicate the conditions.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 03-21-2017, 01:02 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I assume you have tried this with traction control off, and it does the same thing?
Old 03-21-2017, 02:30 PM   #3
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
The dealer isn't going to beat on it lol. They will probably just plug in a computer and try to diagnose the problem. I would go
marknagy13 is offline   Reply With Quote
Old 03-21-2017, 02:33 PM   #4
SS2017
Drives: 2SS & GT Premium
Going by this statement I am lead to believe you haven't tried turning off the TC yet? I mean that can't be possible, as I am sure you would do that before asking on a forum...
SS2017 is offline   Reply With Quote
Old 03-21-2017, 03:25 PM   #5
geaux_tigerss
I'll give that a try. Don't know why it didn't occur to me to try that already.
Summit White
Old 03-21-2017, 04:31 PM   #6
geaux_tigerss
Same thing regardless of traction control, stability control, competitive mode, or all fully off. 93 octane gas from 2 different stations so doubtful it's bad gas. Guess I'll bring it up to the dealer since no one has chimed in saying it's normal.
Summit White
Old 03-21-2017, 08:01 PM   #7
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
As an alternative, you could throw it on a dyno to see if power really changes at those RPM's. Could be pulling timing on some false knock, It would be obvious on a dyno. On top of it, you'll get a nice baseline dyno sheet.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 03-21-2017, 09:03 PM   #8
geaux_tigerss
Originally Posted by cooper1965 View Post
RPM's shuttering the moment this occurs? Or stay steady?
Both the tach and speedometer hang a bit during these surges.
Summit White
Old 03-21-2017, 09:04 PM   #9
geaux_tigerss
Also, just to throw this out there... If a customer comes in with a high rpm issue like you have... First it would try to be diagnosed in shop.. If it can not be duplicated, the only option is to in fact take the car out, and try to duplicate the concern while watching the scan tool live. So to say the dealer wont "beat" on it, is not true.
This is how you handle your situation.
Call your dealer of choice, and ask for the service department. A service writer will answer the call. Remember his name, write it down, whatever.
Tell him you have an intermittent high rpm shutter, and would like to swing by sometime to have a technician ride along with you while it is acting up.
( They will actually appreciate this because otherwise , 2 technicians have to go for one concern. One guy to drive, one guy to view the scan tool)
After he says "sure thats no problem" , just tell him the next time its "acting" up , you will swing by.
When you decide to take it in, simply ask for the service writer you spoke to, and remind him about your conversation. He will pull a technician, he will have a scan tool, and the two of you will go for a ride while he watches the scan tool..
If for any reason you get any grief about doing it this way... FIND ANOTHER DEALER!!
Thanks. Great advise.
Summit White
Old 04-04-2017, 08:30 AM   #10
geaux_tigerss
Update on this. The problem seems likely to be related.
Got a CEL. Onstar said "variable valve timing problem" when they read the code. Car bucks and surges at all RPMs during acceleration and constant speed driving. Almost feels like a big cam with a bad tune. Dropped it off at the dealer this morning. Will post the resolution when I find out.
Summit White
Old 04-04-2017, 09:14 AM   #11
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
CEL will tell them where to look. My bet is a bad sensor on camshaft timing.
Old 04-04-2017, 03:57 PM   #12
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Any updates?
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 04-04-2017, 05:16 PM   #13
geaux_tigerss
Originally Posted by 17ZL1Camaro View Post
Any updates?
Yep. Phone call from the service department this afternoon.
"Sorry we didn't have time to look at it today. Hopefully we can get to it tomorrow, but we're booked solid to Thursday. We're very sorry that you're without a ride to and from work. After we diagnose the problem, and if GM approves, we can put you in a rental for $38/day. Until that happens we have shuttle that can take you to and from the dealership."
I'm pretty far from happy about it. Is this the normal warranty repair experience?
Summit White
Old 04-04-2017, 05:37 PM   #14
Sooner Cole
I would not be happy either. Call and talk to the Service Manager.
19 ZL1-1LE A10
