Old 03-22-2021, 07:59 PM   #15
Z OH 6
Drives: 2024 CT5-V Blackwing
Originally Posted by ZX-10R View Post
Elite design has the restrictor under the blower - where it should be - they calculated max vapor flow through the inlet line and can for optimum separation performance. These cans are still relatively small so high velocity is a problem
It's just another indication MM doesn't really know what they're doing, my Elite E2X has been flawless. I empty it every 3-5k
Horseshit.
Old 03-22-2021, 08:17 PM   #16
20Bluezl1
I had a feeling this would stir up the pot.
Old 03-22-2021, 09:16 PM   #17
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Horseshit.
HAHAHA took words right out of my mouth.
Elite cans have the PCV still built in, the wild is a plug under the SC.
As i said 2 different designs. MM cans work wonderful, OP installer just didn't know what he was doing.
Old 03-23-2021, 09:52 AM   #18
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Horseshit.
LOLLOLLOL
You know, when that guy told me what I was going to do with my car 6 months from now without ever asking me, like he was the freak'in prognosticator god, I was thinking, this guy's an idiot. Since then, He's on my ignore list. I only see replies from him, too many, LOL.
Bangkok_ZL1 is offline   Reply With Quote
Old 03-23-2021, 10:10 AM   #19
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This only happens with the aftermarket valve covers since the baffling is obviously not as good as the OEM ones...
Agree...Primarily the Speed Engineering units.
Horseshit.
This!!
Old 03-23-2021, 11:10 AM   #20
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Based on what? Another member posted pics of significant oil accumulation on the blower and lid running a MM. Again, one has proof, the other has claims
ZX-10R is offline   Reply With Quote
Old 03-23-2021, 11:47 AM   #21
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
There are a lot of CC threads with strong opinions about the need for it, warranty issues, which one is best,etc. I have a few of questions...
  1. Is this mod primarily for modified cars running higher boost and +100 whp, or it it highly recommend for 100% stock cars as well?
  2. If someone is emptying their cc every 1-5k miles, I assume that means that the blow-by exhaust gas would be causing noticeable oil consumption as it escapes past rings and burns the oil on the cylinder walls below piston ring or burns intake oil vapor in combustion chamber, is that correct?
  3. If a car has zero oil consumption either during heavy track use or street use, does that mean they don't need a catch can?
I assume the answer is yes, if there is no oil disappearing from oil pan then it's not being burned by blow-by or vapor collecting in SC or other parts of intake tract.
SFV1LE is offline   Reply With Quote
Old 03-23-2021, 12:02 PM   #22
ZX-10R
ZX-10R's Avatar
The short answer is any boosted engine (unless it has a baffled head, similar to the Honda Type R design) needs a catch can/separator properly sized for vapor flow rate because blowby will accumulate in the intake over time, and in the case of DI engines, fuel doesn't wash off the valves.
The more boost and the harder you drive the car, the worse the problem is
Worth watching, about 6:30 in
Old 03-23-2021, 01:06 PM   #23
gtfoxy
Drives: '21 Wild Cherry ZL1
Originally Posted by Bangkok_ZL1 View Post
LOLLOLLOL
Old 03-23-2021, 01:30 PM   #24
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Agreed!
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 03-23-2021, 03:59 PM   #25
SONiC MOjO
Drives: 2018 Zl1 A10
I didn’t mean to stir the pot, I just don’t know what the issue is. I had an elite2 can in before and it work fine. Going to the Magnuson and SE valve covers my builder said the E2 will no longer work with this setup. So I got the MM, and just have had nothing but issues with it.
SONiC MOjO is offline   Reply With Quote
Old 03-23-2021, 04:38 PM   #26
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I already told u what to do, its not the can. Its the combination of the valve covers and and high vaccum.
Just add a $3 reducer and your problem is solved.
Old 03-23-2021, 05:04 PM   #27
SFV1LE
What's the reason for the Speed Engineering valve covers? I haven't heard of any performance benefit from aftermarket valve covers, are they required in some way for the 2650 upgrade? Or is it cosmetic (they're billet and have a nice logo machined into the top)?
If that's the case, and they're contributing to the problem, you should reinstall the OEM covers. Even if you solve this with a restrictor or different CC, adding a part that creates problems in a vital area of your motor seems like a bad idea.
Old 03-23-2021, 06:30 PM   #28
KingLT1
KingLT1's Avatar
Because you have to modify the stock valve covers for the 2650 to fit. It's no big deal really but some have decided to replace them instead.
