#15 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
I do not know if the entire car would shut down. Can you separate the individual wires that were damaged? If so I would tape the damaged insulation. I'm not sure how far from the connector the damage is but you could also try and remove the wires from the connector and then slide heat shrink tubing over the wire and reterminate into connector. Did the actual copper get damaged? That sucks but it is a very tall tire and a reason I'm going with a 19 inch wheel, drag radial available in stock diameter tire
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#16 |
![]() ![]() ![]() Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
This happened to a co-worker when he put drag radials on. He said that his gauges started going crazy. He had a guy that he knew fix the wires or replace the whole thing (don't remember) and then re-locate them.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
#17 |
Drives: 2016 2SS Join Date: Mar 2014
#18 |
He is hip to that now, for sure.
#19 |
I used to be Dragoneye...
The harness is simply an organized path for wires. If one out of 8 get burned...then just that one component will not work...the computer won't know or want to shut down the rest of the circuits.
#20 |
#21 |
![]() Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
Not to de-rail, curios why I see so many running a 305/35R20 instead of a 305/30R20? 305/30R20 is already the proven factory size for the 1LE, why deviate from that?
#22 |
I know if your looking to put a drag radial on that's one reason why.
#23 |
![]() Drives: 2016 2SS Red Hot Join Date: May 2016
Ender, can you post a pic of the harness damage? Much easier to determine a fix if we can see it. If it's just chaffed and not worn through you can likely do a quick fix, relocate it and wrap it in some protective spiral wrap to reduce the possibility of any future chaffing it the relocation wasn't good enough.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Unless that one wire powers the fuel pump. Then you may be dead in the water.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#25 | |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Now that I have them the larger diameter does fill the wheel well nicely, give a little more ground clearance lowered, and has a little softer sidewall for marginal TX backroads. My preference will be a 315 but options are slim to none.
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#26 | |
315 R20 is hard to find a decent price street able tire :( |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Pics please
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#28 |
Did you get it fixed?
