Old 09-15-2016, 06:51 PM   #1
ender2664
Drives: 2016 2SS
305 rubbing damage
Did anyone have their 305s not just rub the wheel well but get all the way through the well and hit the wires? If so what were the effects of hitting the harness and how did you fix it?
I personally had mine tires hit the harness and cause the protective layer burn off and had damage to some of the wires causing a code and fuel pump issue.
However I'm told if the harness had even a little bit of damage the whole car would not work which seems strange because mine worked fine with the exception of the pump problem.
Any experience and knowledge would help a lot!
Edit:
Please notice the question does not ask if you had just rub.
ender2664 is offline   Reply With Quote
Old 09-15-2016, 07:02 PM   #2
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
what are the rest of your tire dimensions and wheel size and all that? I'm curious cuz I've heard of others with 305 not have issues and some with initial rubbing that went away
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 09-15-2016, 07:03 PM   #3
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
If you have stock sized tall tires you will get rubbing issues.
I had to go with 305/30/20's to avoid the rubbing issue.
Sledgehammer70 is offline   Reply With Quote
Old 09-15-2016, 07:07 PM   #4
Mojave
San Diego Head Tuners
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
Were you able to stay on that size even after you dropped yours?
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Member of San Diego Head Tuners
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
http://dinowax.refr.cc/bryanm 15% off DinoWax orders
Mojave is offline   Reply With Quote
Old 09-15-2016, 07:08 PM   #5
Sledgehammer70
Lethal Camaro
Yup. I haven't seen any rubbing yet. Will check again this weekend.
Old 09-15-2016, 07:11 PM   #6
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
My car must sit different because I do not rub on lowered 305/35/20
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-15-2016, 07:14 PM   #7
ender2664
Drives: 2016 2SS
Mine is not lowered
Old 09-16-2016, 05:56 AM   #8
laynlo15
Drives: 2022 Lt1 A10
I tried the 305's and yes they did rub the area where the harness runs. I went back to the 295-35's, its perfect
Old 09-16-2016, 08:06 AM   #9
Fraxum
Fraxum's Avatar
I moved the harness and everything is fine. 305-35-20, not lowered. But because of where the rubbing is happening I am not sure lowering matters.
Old 09-16-2016, 08:44 AM   #10
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
I moved my harness and have not had any problems , mine is lowered, and on 305/35-20
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 09-16-2016, 09:11 AM   #11
ender2664
Drives: 2016 2SS
Old 09-16-2016, 09:33 AM   #12
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
I haven't experienced this problem but the obvious fix would be to repair the wires and either move the harness or change tire sizes. If you didn't fry any electronics consider yourself lucky.
02fbody35th is offline   Reply With Quote
Old 09-16-2016, 09:43 AM   #13
ender2664
Drives: 2016 2SS
Since their are many individual wires in the harness I need to repair them one at a time, correct?
I was told, but do not believe, if even one wire in a harness becomes damaged that the whole harness shuts down. Is that correct?
Old 09-16-2016, 09:54 AM   #14
Egon
Egon's Avatar
Drives: 2014 2SS/RS 1LE
Hey wanted to say I love your videos but you made me cringe when you were laying down with your head and legs under the car without jack stands. Sorry to be that guy, but please be careful so you can keep making us videos.
Egon is offline   Reply With Quote
