Old 03-23-2025, 11:40 PM   #16101
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by Bumbleboy92 View Post
Much better, looks great!
Old 03-24-2025, 06:38 AM   #16102
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Originally Posted by 2018 Blue 1LE View Post
Added a Sequenced third brake light with lighted switch and inline fuse.
So what's the switch for? To turn your sequenced brake light on & off?
My Camaro Journal
DamonZ28 is online now   Reply With Quote
Old 03-24-2025, 07:34 AM   #16103
p47dman
Drives: 2024 Camaro 1SS
Started to cover knee bolsters with new material and 1/8" foam pad.
p47dman is offline   Reply With Quote
Old 03-24-2025, 11:41 AM   #16104
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
https://photos.app.goo.gl/nDMyFow6UXk1Ncxa9
Shift knob from Speedawg.
Added the foot well lighting.
Driver's side is zip tied for now. The hole it is supposed to go in is blocked top and bottom with wiring harnesses. Even if it wasn't, not sure the plug would survive with the clutch there and there is no room to go the other way.
Colors are the same, just a camera compensation for some reason.
Not sure why the photos went sideways here.
Looks good!!
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 03-24-2025, 11:42 AM   #16105
willzilla
D3RPZILLA
willzilla's Avatar
Most likely it lets you enable "show mode" which can play a different pattern or whatever when parked. That's how I have mine setup.. I can park and shut off car and enable show mode and it does a cool effect
Old 03-24-2025, 04:01 PM   #16106
NjaTrtl
NjaTrtl's Avatar
Drives: '22 2SS 1LE M6, '12 Audi Q5
Amazing how such a little part can make such big improvement.
I ordered mine with the black lugs/locks and I'm always amazed at how many car manufacturers don't automatically include them with black/dark wheels.
1st - '65 Ford Mustang - Candy Apple Red
2nd - '77 Pontiac Trans Am - Black/Gold
3rd - '79 Pontiac Trans Am - White/Gold
4th - '86 Chevrolet Camaro IROC Z28 - White
5th - '91 Ford Mustang GT M5 convertible - White
6th - '00 Chevrolet Camaro Z28 M6 - Rally Red
7th - '12 MINI Cooper S M6 - Chili Red
Last - '22 Chevrolet Camaro 2SS 1LE M6 - Rapid Blue
NjaTrtl is offline   Reply With Quote
Old 03-24-2025, 07:49 PM   #16107
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
BRAKE = this pattern is activated upon hitting the brakes. This pattern will run for 3 seconds and then ALL the LEDs will come on solid until you let off the brake.
SHOW = this pattern is activated when the "show" wire is connected to any 12V+ source, this can be done using our Show Mode Easy Install Kit (sold separately), a switch at your dash or connected directly to your vehicles tail/running lights. Connection must be a 12V POSITIVE source. If the SHOW mode is on, and you hit the brake, the BRAKE pattern will always override the SHOW pattern for as long as the brake is held down. The show pattern will resume once the brake is released. The show pattern is a continuous sequence.
Copied from their website.
https://seequenced.com/collections/f...39289022546005
2018 Blue 1LE is offline   Reply With Quote
Old 03-28-2025, 09:23 AM   #16108
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
I upgraded my phone to a (used) Samsung S23 that finally came within my hard budget ($199) after discounts, and guess what, IT FITS PERFECTLY on the wireless charging pad after trimming the long edge end caps, which I already did years ago.
Yes, we all know GM effed up with this constrained design, but where there is a will, there is a way. If one wants, they can wirelessly charge a reasonably modern phone and use wireless Android Auto with 6th gen Camaros, even pre-refresh ones.
You got a link to a post on how to do this mod? I was always irritated my 15 Pro Max doesn’t fit. I think it’s about as big as an S23.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
Old 03-28-2025, 12:47 PM   #16109
Yup, it's trivial if you have a sharp utility knife or an X-Acto, check out this thread: https://www.camaro6.com/forums/showthread.php?t=611789
The S24 and S25 should fit as well, they aren't significantly larger than the S23. Big slappers like the plus and the ultra won't fit, of course.
Old 03-28-2025, 01:35 PM   #16110
PowerDemon
PowerDemon's Avatar
Ah I have a Max which I think is about the same size as an Ultra :(
How do you remove the rubber mat to trim it? Can I just pull it out?
Edit: Kept reading and figured it out. Thanks
Old 03-28-2025, 02:56 PM   #16111
2018 Blue 1LE
Got windows tinted today.
It's raining, so just some quick shots between the drops.
Old 03-28-2025, 03:04 PM   #16112
2018 Blue 1LE
This mod to the rubber is only going to work if the phone will fit inside the hard plastic of the console.
At this time, both phones I have are too big to sit inside the plastic and therefore the mod is pointless.
I am thinking of getting the cubby and adding a charger port to it that you can plug a cord into.
I am thinking of using the power supply for the wireless charger that I am removing.
Old 03-28-2025, 08:06 PM   #16113
Ryanbabz71
Ryanbabz71's Avatar
Just got back from vacation and had to go for a drive after driving a 4 cylinder VW atlas for a week . This car is insane with 200 more hp than my previous SS
Also added the trunk pull
Sent from my iPhone using Tapatalk Pro
Ryan
Old 03-28-2025, 08:22 PM   #16114
Yeah, unfortunately it's a shortsighted design, the plastic ridges on the side, and even more overall tray dimensions are a hard size limit.
Luckily for me, I don't like giant phones, and even the latest Samsung Galaxy models come in sizes that fit.
If you're adventurous, you could try to fab a center console armrest with an adapted Silverado charging kit, similar to what a forum member did (only with wired charging, though), see here: https://www.camaro6.com/forums/showthread.php?t=602888
