Old 12-03-2022, 08:16 AM   #1
SMURFSUP
Drives: Rapid Blue 2023 2ss 1LE
Factory Wireless Charger
Im curious if anyone elses phone is just to large to charge on the wireless charger?
The phone will sit on an angle because of the length of it compared to the little inlet for the phone to sit.
Anyones phone still able to charge like that? I dont really have a smaller phone to test that out on. Otherwise i might be searching for a phone that will 100% fit in there and charge lol
Just curious as to what others have had to do. Or is it something that needs to be turned on in a setting somewhere? I am currently going through the owners manual but i havent found anything yet.
Mike
1981 Camaro Bahama Blue. 510BigBlock
2023 Rapid Blue 2SS 1LE
1100 - 08/29/2022 ----------------------- 4000 - 11/03/2022 Vehicle Available to Ship
2000 - 09/12/2022 ----------------------- 4V03 - 11/20/2022 Estimated Delivery Date
3000 - 09/27/2022 TPW-10/24/2022 ----5000 - 11/16/2022 Arrived at Dealership
3800 - 11/03/2022 Vehicle Produced ----6000 - 12/01/2022 Customer Picked Up Vehicle
SMURFSUP is offline   Reply With Quote
Old 12-03-2022, 09:17 AM   #2
Even if the phone does charge, it will bounce around if it isn't sitting on the rubber mat.
What I did about the same problem in addition to upgrading to the higher spec 2019+ wireless module was trimming the shorter ends the rubber, see below, which allowed my phone to fit. (The light gray color along the surface of the cut is just the phone's camera playing tricks, it's the same color as the pad.)
The wireless charging pad design in this car is quite shortsighted, unfortunately.
Old 12-03-2022, 10:15 AM   #3
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
I'm surprised no one makes a replacement that will fit larger phones.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 12-03-2022, 10:58 AM   #4
SMURFSUP
Ohh thats awesome thanks. What is the upgraded charger?
Yea really
Mike
Old 12-03-2022, 11:47 AM   #5
It's GM part number 84526978 (or 19421449).
FYI I've also attached the last wireless charger compatibility list I used, there might have been updates to it since then.
File Type: pdf GM Wireless Charging Compatible Devices (Aug 2019).pdf (15.5 KB, 388 views)
Old 12-10-2022, 04:49 PM   #6
Nate76
Nate76's Avatar
Drives: 2022 2SS Convertible
Just wanted to say thanks for the hack! My iPhone 12 finally fits. Everyone with a phone that’s todays size should do this.
Nate76 is offline   Reply With Quote
Old 12-10-2022, 06:59 PM   #7
Glad to hear it worked for you, too
Old 12-13-2022, 06:00 AM   #8
SMURFSUP
Same thanks!
it blows my mind that they didnt make it long enough to fit. Suck cutting it up but heck it works now!
Mike
Old 12-13-2022, 12:41 PM   #9
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
what did you use to trim it with? How did you remove the unit?
Anjilslaire is offline   Reply With Quote
Old 12-13-2022, 08:54 PM   #10
You can simply lift the rubber pad with a plastic trim tool or maybe even just your nails, it isn't attached to the plastic tray. I trimmed it with an x-acto knife.
Old 12-14-2022, 11:09 AM   #11
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I'm going to try this trim modification but the thing I've not really seen it as more than a impractical gimmick due to it's location for the most part. No way it will ride there the way that I drive LOL
Old 12-14-2022, 01:57 PM   #12
Anjilslaire
Agreed, lol
Old 12-14-2022, 02:06 PM   #13
Agreed, lol
I have a case with a rubber backing, the phone stays put on the rubber pad all right
Old 12-14-2022, 02:12 PM   #14
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
This might be a springtime mod. Although I have a legit wireless charger in my 2021 F150 that really don't use much. I have an S22 Ultra that's big and I doubt the "mod" would work for mine.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black
Jus Cruisin is offline   Reply With Quote
