Old 03-16-2026, 09:57 PM   #1
1le Maro
1le Maro's Avatar
Drives: 2022 Camaro SS 1le
Engine oil priming
Im close to pulling out the car after being stored all winter. I have seen some people priming the engine oil on their corvettes after sitting for a while by pressing the gas pedal down and pushing the start button letting the engine crank over for a few seconds without it firing up to prime the engine with oil before starting. I am wanting to know if the same process works with the Camaros. Thanks
1le Maro is offline   Reply With Quote
Old 03-16-2026, 10:22 PM   #2
piening2150
Drives: '23 2SS 1LE 6MT
Yes. Works for most modern cars.
piening2150 is offline   Reply With Quote
Old 03-17-2026, 06:53 AM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Press the gas all the way to the floor and then crank it. If your just press it partially it will start and immediately go to high rpm
Old 03-17-2026, 08:59 AM   #4
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
At least 85% accelerator pedal is required, so pedal to the metal.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 03-17-2026, 09:39 AM   #5
bishopts
bishopts's Avatar
I'm not really sure why, but its a percent you can change in hp tuners.
Old 03-17-2026, 10:55 AM   #6
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Modern... Does this work on something like a 2000 Camaro as well?
Bad Anvil Garage is offline   Reply With Quote
Old 03-17-2026, 11:06 AM   #7
bishopts
bishopts's Avatar
I have a 99, gimme a little bit and i will try
Old 03-17-2026, 11:13 AM   #8
piening2150
I think any GM vehicle with fuel injection will have clear flood mode. Most OBD2 cars have it. I have not personally tried it on anything older than about 2005.
Old 03-17-2026, 12:01 PM   #9
bishopts
bishopts's Avatar
It does work with my 99 SS.
Old 03-18-2026, 01:46 PM   #10
Bad Anvil Garage
Thanks for checking. Just put it to the floor and turn the key?
Old 03-18-2026, 10:54 PM   #11
bishopts
bishopts's Avatar
Yes, hold it down. If you let it off the floor while your still cranking , it will turn on the injectors and start very aggressively lol.
Old 03-19-2026, 12:37 AM   #12
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I rarely drive my car, so it sits a lot... For clarity, is this the procedure?
- Push accelerator pedal all the way to the floor and hold it
- Push and hold start button for several seconds (to prime the oil, guessing 3-5 seconds, car will crank but not start)
- Let go of start button, after cranking stops, let off the accelerator pedal
- Start car normally (with "primed" oil system)
Please let me know if this is correct, I had never heard of this before, but plan on using this after long sits (1+ months)...
Old 03-19-2026, 06:29 AM   #13
bishopts
bishopts's Avatar
Yes. Exactly.
I use this procedure for other applications too. Checking compression, clearing fuel fouled spark plugs (technically why is there), checking flywheel to starter tooth engagement, starter volt drop test. Im pretty sure i explained this procedure in one of the many slow crank threads we have.
Old 03-19-2026, 11:34 AM   #14
2SS Capt
2SS Capt's Avatar
Yes. Exactly.
Thank you!
