![]() Drives: chevy camaro Join Date: Sep 2022
amsoil oil filter
hello so what are the thoughts on the amsoil filter vs the pf64? i do beleve it has the 22 psi bypass built-in, amsoil-EA15K50 is the filter.
thanks |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Consider a Wix filter. Been using them for many years, the best.
#3 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
Hope this helps! LMK if you would like to receive discounts on all Amsoil products. |
I've been using the EA15K50 for years with no issues, for the same reason, ie its much better filtration capability. It also has a nice grippy surface on the outside, very easy to spin off and on even with oily gloves.
The incessant revisions to the PF64 don't inspire much confidence in me either, I'm afraid GM aren't exactéy doing it because they want to make that filter better and better.
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I tried to research this but nothing looked different: What's the difference between the EA15K50-EA and the non -EA (EA15K50) ?
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
#7 |
thanks for the replys
i have both filters in house and i think i will go with the amsoil filter after reading these comments thanks. |
#8 |
It's the same thing. Maybe some aspect of their internal coding differs from the customer facing part number.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 03-05-2026 at 06:24 PM. |
#9 |
![]() Drives: 2022 Camaro V6 2LT Convertible Join Date: Jul 2021
I use the WIX which are manufactured by Mann & Hummel.
I’m putting together the parts list for my next project: installing a Frantz bypass oil filter to filter down to 2 microns. The plan is to install a Mishimoto sandwich adapter at the OEM oil filter location and tap a 1/4" supply line from the adapter to feed the Frantz filter. The filtered oil will then return through the oil fill cap. I currently have a clean-side oil separator from Tracy Lewis, but I’ll need to repurpose that separator for the oil return line from the Frantz filter. Because of that, I’ll be adding another catch can — a Mann & Hummel ProVent 100 v2 — to handle the crankcase ventilation between the valve covers and the existing air intake nipple. It should be an interesting project. Once everything is complete and I have some results, I’ll post a full write-up in the DIY section. |
#10 | |
I would recommend against using the Mishimoto Sandwich filter adapter for an oil cooler. I will say I have ZERO experience with the V6 platform, but if its like the LT4, the sandwich adaptor can lead to bypass issues at higher RPM. I have several customers who bought that system only to have massive cooling issues when at the track. Around town driving with low RPM sustained use, it works fine, but in a track environment, it miserably fails. Also understand their heat exchanger was designed to flow Glycol based coolants, not oil... so the flow rates are also an issue and have been known to cause starvation at high RPM again in the LT4s leading to a bypass. |
#11 | |
The spacer is designed to provide ports for measuring oil pressure or temperature, or, as in my case, to route a small portion of the oil (about 5% flow) to a secondary filter, such as a Frantz bypass oil filter. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I use the Mobil 1 113 and have no issues.
#13 |
