Old 02-23-2026, 11:01 AM   #1
Carbonflash22
Drives: 2022 M6 ZL1
Smoked the clutch - now what
I'll admit I screwed up and have probably done some damage. My question is how much and what should I do about it now?
My rear tires are at their end of life and I wanted to do a few burnouts before putting on the new ones. I've driven within restraint so I've never attempted a burnout with this car before. I engaged the line lock, however, I smoked the clutch pretty good before I realized what was happening. It seems to shift okay but smells really strong. Should I take it in to be looked at and what could I expect if it needs to be repaired for costs?
Carbonflash22 is offline   Reply With Quote
Old 02-23-2026, 11:21 AM   #2
beowulf556
Drives: Camaro SS 1LE M6
Sounds like you glazed it. The smell will go away. If it's shifting ok I wouldn't jump to replace it just yet.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 02-23-2026, 11:47 AM   #3
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I agree with beowulf556. I'd drive it easy for a while to see how the clutch holds and shifts. It should improve. If not, then I'd budget for an OEM replacement or an upgraded Triple Disk from Monster. I did this upgrade a few months ago and love it.
Old 02-23-2026, 01:55 PM   #4
ctrlz
If it's not slipping or making noise you probably just cooked (glazed) some of the friction material. It may need to wear a bit before it grabs as well as it did pre-cooking.
Your main trouble would be:
1) You got it so hot it partially shattered and now you have friction material getting tossed around.
2) It grabs irregularly, shocks the mechanism, and breaks metal parts.
Old 02-23-2026, 02:17 PM   #5
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Can you describe the feeling of the multi disc clutch. Does it engage smoother or the same? Does the pedal feel tighter or the same? Does it have a narrowed window between contact and full hold?
Old 02-23-2026, 04:39 PM   #6
SOCAL.M6.ZLE
Great question... I was VERY skeptical when reading Monsters website about the Triple S driving like stock, but it 100% does. You would never know it had a triple disk, or an upgraded bearing support. Just much better holding power...
For me, the biggest difference was going with the ultra lightweight flywheel which helped me save 17pounds over the OEM dual disk.
That is the part I was most worried about. Honestly, I prefer it. You do need to give the car a little more gas at a stop light due to the reduction in rotational mass, but after that, shifting feels so much faster. I would not change a thing.
Old 02-23-2026, 06:22 PM   #7
bishopts
bishopts's Avatar
Interesting that it uses a LUK friction disc. That's a major supplier for oem parts, i guess aftermarket sources from them too. Was the lightweight flywheel nessisary for your built? Or was it the only option for that clutch set?
Old 02-23-2026, 11:15 PM   #8
SOCAL.M6.ZLE
Good question, it was not necessary, just an option I really wanted to try. A few people told me I would regret it, and a few people told me they loved them, so I went with the ladder, and have no regrets.
Old 02-24-2026, 07:22 AM   #9
LTfun
Drives: 2022 LT1, 1981 320i
Any issues with active rev match or does the computer just drive to RPM such that it doesn't make a difference?
LTfun is offline   Reply With Quote
Old 02-24-2026, 08:11 AM   #10
SOCAL.M6.ZLE
No issues at all!
Old 02-24-2026, 08:47 AM   #11
Carbonflash22
Drives: 2022 M6 ZL1
I appreciate the feedback from everyone. After letting it sit for a day I took it out for a drive and shifting seems pretty close to normal. Starting off in first seems like it needs a little more gas to get going smoothly but that's the only thing I've noticed paying close attention to each shift now. I'm not hearing any unusual noises. It seems I may not have caused any serious damage, only shortened the life. The Monster Triple S looks like a nice option for a future replacement/upgrade.
2022 M6 ZL1 | Catback AWE
Old 02-24-2026, 02:26 PM   #12
SWFLZL1
Drives: 2022 ZL1
Curious as to what rpm didn’t spin the tires, and smoked the clutch? Did you just drop the clutch at too low an rpm. Just wondering, as I have never tried the line lock on mine yet either.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 02-25-2026, 11:06 AM   #13
bishopts
bishopts's Avatar
I would guess dragged the engagement out more than dumped it. Once you do that its harder to get the stationary part moving than it is to slip across it. Its basically brake fade but in the clutch.
Old 02-25-2026, 02:42 PM   #14
TransamGTA350
Drives: 2023 Camaro SS1LE
As others have said, probably just glazed the clutch disc. Pretty common thing to do. Drive it for a while and will likely wear the glaze off and work normally after 50-100 miles. If it doesn't get better, then time for a new clutch.
2023 Camaro SS1LE
1989 Trans am GTA
TransamGTA350 is offline   Reply With Quote
