Old 02-03-2026, 11:55 AM   #1
Mark20242SS
Mark20242SS's Avatar
Drives: 2024 Chevy Camaro 2SS
Throttle sensitivity when cold
Have done some research on this, but wanted to ask when I first leave for work in the morning when it has been cold out the throttle will be sensitive when going from a stop. it will be fine after it warms up more. what causes this?
I will just have to start warming it up longer I know before leaving now, I had been warming it up for a couple minutes in the garage.
was also researching the drive modes and is track a good mode to use in town driving? read it was the most linear mode for throttle mapping. I had been using sport for town and use touring on the highway for better mileage.
also just read about those soler throttle controllers you can get. do those really help? just plug it into the ecm port under the dash and put the screen on the dash? never used one of those before. thanks for any information!
Mark20242SS is offline   Reply With Quote
Old 02-03-2026, 12:52 PM   #2
2023-SS
Drives: 2023 SS
in for Throttle Commander comments....
are they worth $300?
2023-SS is offline   Reply With Quote
Old 02-03-2026, 01:19 PM   #3
sscentex
Drives: 2016 Camaro SS
Throttle is more sensitive when warming up cause the throttle blade is already open more for the higher idle to help warm the car up (horrible explanation but that's the gist).
Driving mode is user preference. I use sport for everything.
Skip the pedal commanders and just get an actual tune. More expensive but much more can be changed and adjusted.
2016 Camaro SS
sscentex is offline   Reply With Quote
Old 02-03-2026, 03:50 PM   #4
Mark20242SS
thanks for the info! yeah will have to let it warm up longer when its cold out from now on.
I am going to try using track mode and see how I like it compared to sport in town driving also.
I have my steering, suspension, and exhaust set to not change so it will just be different throttle feel, shifting.
my steering is set to sport, suspension to tour, and exhaust to track.
Old 02-03-2026, 07:36 PM   #5
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Track mode is definitely the most linear. If I recall correctly, Sport mode is most weighted toward the low end (least linear). So if you want less throttle sensitivity, especially when cold, start in Touring mode or Track mode.
Now that I think about it, Rain/Ice mode would probably be the best when starting cold. In this mode, TCS will retards throttle input the most because it thinks the payment is slippery, and it closes the exhaust valves which will make the car warm up faster. Just remember not to leave it in Rain/Ice mode once it's warm or the engine/oil may get warmer than you want it to if you start driving aggressively with the throttle.
N Camarolina is offline   Reply With Quote
Old 02-04-2026, 04:49 AM   #6
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Also basic physics.
Colder air is more dense than warmer air.
Your throttle response will improve under those conditions as your AFR and power changes with air temp, atmospheric pressure, density and altitude.
And yes driving on snow even with snow tires is very difficult with my setup, not impossible just difficult. I have to be extremely careful how much gas pedal I use with my setup.
Even a slight inclined stop sign in 1" of snow can be a futile effort even with snow tires. So I have to laugh at people who talk about tires especially A/S tires. Even at stock power levels it is a chore to say the least. I've gotten stuck at said stop signs in 1" of snow with snow tires, and not gone anywhere, or worse yet, even slid backwards while holding the brake pedal.
Old 02-04-2026, 04:54 AM   #7
FlukeSS
FlukeSS's Avatar
Track vs Sport mode is relevant to the amount of gas pedal you use.
Sport is designed for less pedal more power
Track was explained to me as a 1:1 ratio (most accurate)
Touring less power with same pedal pressure
Snow/Ice less power with same pedal pressure relative to Touring.
Aside from the 1LE configurations which also has changes to suspension dynamics as well.
Old 02-04-2026, 07:41 AM   #8
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I have noticed this phenomenon in every car I’ve owners, especially manual transmission cars. It’s normal. I tend to let my stuff warm up a bit before I drive the so I don’t experience these issues at all
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 02-04-2026, 09:12 AM   #9
2023-SS
Drives: 2023 SS
my last tune was $960 (did not put a Stall torque converter in with a Stage 2 cam)
somebody gave me a Throttle Commander (huge bundle buy when a guy sold his camaro), the Free factor made me question how useful they are.
you gotta think about an old Carb'ed car.
they had a High Idle when cold, to keep running.
a Fuel injected car is the same, it has to have more RPM to keep it running while cold, then it will idle down to the base RPM.
you can see those RPM values in your tune or hand held programmer for cold & hot idle RPM.
I like a remote start for those reasons.
wife has a honda SUV, it will LURCH into Drive if it is cold, due to the high idle. we have to back it in, so it pulls straight out on cold mornings.
if you try to reverse with the high idle, it's no fun.
manageable, but annoying in this world of super smooth luxury cars.
Old 02-04-2026, 09:55 AM   #10
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Hi there,
Yes, our Soler throttle controller does help significantly with throttle sensitivity and overall pedal feel in all driving conditions.
The controller does not plug into the ECM port under the dash. It connects directly to the throttle pedal itself. You also do not have to run the display if you do not want to. The unit can be fully concealed and controlled through our Bluetooth app on your phone.
Most of our customers find Sport 5 to be the most linear and natural feeling setting. The controller works on top of your factory drive modes, so you can think of it as an additive or multiplier that fine-tunes throttle response rather than replacing your factory throttle mapping.
Here is the link to the throttle controller for your car:
https://www.solerengineering.com/gen...tors/se0525-tc
You can use code TIFF5OFF at checkout. We also offer a 30 day money back guarantee and do not charge restocking fees.
If you have any questions, feel free to reach out.
-Tiffany
251-468-9786
support@solerengineering.com
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 02-04-2026, 01:34 PM   #11
Mark20242SS
thanks for the info! yeah I tried the track mode and it is much smoother, think I like it more after a day of use. will see how I keep liking it after more driving. used track this morning and never had any throttle lurches. i also let it warm up a little more and it is not as cold this week.
i may go to track for town driving and touring for highway from now on. and I did use snow mode a couple weeks ago and had no issues with spinning, the roads were not real bad though. i have michelin all season tires.
