Old 01-06-2026, 07:14 PM   #1
ShadowLT1
ShadowLT1's Avatar
Drives: 20' Camaro LT1
So how reliable as your 6th Gen been so far?
So how reliable has your Camaro been so far? I bought my 2020 Camaro LT1 A10 in May of last year at 20k miles, I now currently have 29k miles and I daily drive mine with zero issues so far other than I had to replace the original GM battery. Would love to hear yalls experiences!
ShadowLT1 is offline   Reply With Quote
Old 01-06-2026, 07:59 PM   #2
sscentex
Drives: 2016 Camaro SS
Bought my 16 with 87k miles two months ago and judging by the service records it came with it’s been dang good. Tuner shop said I had a good year. Hoping she serves me well for several more years.
2016 Camaro SS A8
Borla ATAK
Tuned
Drag DR77 Wheels
sscentex is offline   Reply With Quote
Old 01-06-2026, 08:07 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I'm at 108k, i replaced the battery last year. It didn't have a no start issue but it felt slow to crank after sitting for a couple days.
The driver seat bolster was worn so i replaced that upper seat skin. At about 103k i think.
My driver inner door handle chrome started peeling. It's not really bad but all i need to do is install the part.
I had a no start issue around 101k and it was the remote control door lock receiver. It wasn't detecting the key when it was in the car.
Nothing has leaked. The clutch is still strong.
I did remove all the trim panels on the engine, mainly because it's a unnecessary place to hold heat on the engine.
Its not the most reliable vehicle I've owned but it's very reliable.
bishopts is online now   Reply With Quote
Old 01-06-2026, 08:26 PM   #4
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
The only big problem is it keeps getting speeding tickets.
cgdelena is offline   Reply With Quote
Old 01-06-2026, 08:32 PM   #5
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
Got mine September of 2022 and as it sits now, I have 1,069 miles on it...so probably not even "REALLY" broken in yet. It's also not a daily driver. But to date, I haven't had any issues yet.
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 01-06-2026, 08:57 PM   #6
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Originally Posted by bishopts View Post
I'm at 108k.....
108K Miles and still on the original clutch? Good to know they are robust when driven properly!
Got my 2023 new with 10 KM on it, has around 25,000 KM on it now. So far it's been pretty rock solid. Had a couple check engine lights over the first year or two, checked it and was some emission code. Took it to the dealer each time, after the second time I haven't seen it since.
Otherwise, the only things I've had to do are regular fluids/filters maintenance. All done overly early because... just because.
speedyink1 is offline   Reply With Quote
Old 01-06-2026, 09:01 PM   #7
david_acm
david_acm's Avatar
Drives: LT1
I got mine new in April 2022 and recently crossed 62k miles. It's my "daily driver" in that I drive it everywhere for any reason, but I don't commute to work.
I do all my own maintenance and the only thing that went wrong is I had the starter die after a year (no clue what happened but it was covered under warranty). I also changed the spark plugs last year after a track day. Other than that it has just been fluid changes and tires/pads.
Additionally, I added a second ground wire in the front to help with lazy starts when the car is hot and an oil catch can to help delay the inevitable valve cleaning.
david_acm is offline   Reply With Quote
Old 01-06-2026, 09:11 PM   #8
cdb95z28
cdb95z28's Avatar
Rock solid '22 SS 1LE A10, 18k miles, bought new. Over 2400 miles of track days and a handful of fun drives on the twistys of the Smokey Mtns.
"KEEP THE FAITH"-Fbodfather
Old 01-06-2026, 09:59 PM   #9
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
2 years and 22k miles by me, 28k miles total. No problems, added a 2nd ground wire up front and probably need a new battery sooner than later. Car gets more attention than my 'vette.
cadyshac is offline   Reply With Quote
Old 01-06-2026, 10:58 PM   #10
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
My 2020 2SS is about to turn 6 years old in 11 days (well, since delivery)... Certainly not a daily driver as it only has 11,500 miles and has never seen rain, etc... No real issues per say, probably need to start thinking seriously about a battery (and it is due for an oil change (1 year time, certainly not by the mileage as the oil only has about 800 miles on it, but it is at a year old in the car.))
The only significant issue I had was this one (Code P0700 / U0100 (2020 2SS, A10)) however there was a recall for it which just required a ECM flash from the dealer, not a problem since... I do all of my own maintenance and everything has been fine...
Old 01-07-2026, 06:14 AM   #11
NashZL1
Drives: 2022 Camaro ZL1
2022 ZL1 with 17k miles. Only issues were a loose vapor return line when new causing a CEL and a burned out passenger side DRL same time. No other issues. Just regular maintenance.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 01-07-2026, 07:50 AM   #12
Brewmaster
Brewmaster's Avatar
Drives: 2017 2SS 50th Anniversary
2017 SS with 18k Miles - I purchased 9 years ago with 500 miles.
8l90 TSB performed under warranty for shudder-
Steering rack replaced under warranty for recall
Windshield washer pump replaced
Serpentine belt tensioner leaked and replaced
Installed Antigravity after 8 years but original battery was still cranking
I'm happy with all of this except the A8- but I trust it will be ok after new fluids and future maintenance.
Brewmaster is offline   Reply With Quote
Old 01-07-2026, 07:52 AM   #13
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Bought my 2016 SS in August of 2017 with 900mi. It currently has 20k miles...15k of that is with a Whipple supercharger mounted where the intake manifold use to be. I have had to change the hydraulic tensioner for the serpentine belt and 2 batteries. The batteries were partly my fault because I wasn't keeping the car on a float charger. Since I started doing that my current battery is going on year 5. It's been a good car that is fairly quick. low 6 second 60-130 and traps 138 in the 1/4 in full weight in street trim.
KingLT1 is online now   Reply With Quote
Old 01-07-2026, 07:58 AM   #14
wang970305
Drives: 2021 Camaro 2SS
bought my 2021 2ss new on 9/11/21, currently has 28K miles, tuned by GPI, has not issues except oil pan was dripping oil a month ago, but powertrain covered it wit free oil change~
sometimes the interior panel makes some noise, other than that, im really happy with it!
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is online now   Reply With Quote
