Old 01-03-2026, 10:37 PM   #1
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Auxiliary radiators and Mishimoto hoses
I eneded up puncturing the driver's side auxiliary radiator and will need to replace it.
I got it off through the wheel well, not easy or fun!!!
Saw a video a video afterwards that shows taking off the bumper, and underneath pans.
Questions now are
1) should I just put in the one and use OEM or should I replace both with the Mishimoto?
2) Are the Mishimoto hoses worth the hype?
I notice they supply worm drive hose clamps and have read more negative than positive about that type of clamp.
I don't do any track/racing, just some spirited weekend driving.
At some point I might do some track driving.
Any input appreciated.
2018 Blue 1LE is offline   Reply With Quote
Old 01-04-2026, 12:19 AM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Questions now are
If the oem parts were fine before you attacked them. You will be fine running new ones that are less damaged.
But if aftermarket ones provide other benefits for the same price. Like better cooling without sacrificing reliability. Then its up to you to decide if it's worth it. The way i look at it is, if i can get away from plastic tanks then i will, because reliability is usually better with all metal on the radiator.
Old 01-04-2026, 01:21 PM   #3
cdb95z28
cdb95z28's Avatar
The Mishi hoses are not needed. OE hoses last forever nowadays. Maybe the Mishi coolers are more robust than the OE ones, so that might be a plus. Definitely vacuum bleed your system. Myself and a few friends have had air pockets in these complex systems after getting into them. A regular passive fill was not enough and it ended up ruining our track days.
"KEEP THE FAITH"-Fbodfather
Old 01-08-2026, 10:37 AM   #4
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I agree, if your temps were fine before, I would just replace with OEM. The ZL1's benefit from THESE CSF versions when upgrading to the larger fittings and hoses, but I don't think they would be worth much on a stock LT1.
