Old 12-02-2025, 07:52 PM   #1
Laguna Crazy
Drives: ZL1 stick w track Mods
Brake Pads
I'm having trouble finding the OEM pads for my 2018 ZL1 they are brembo C3641200.
I only track the car so i am open to ideas about better pads and rotors.
Laguna Crazy is offline   Reply With Quote
Old 12-02-2025, 07:59 PM   #2
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Go hit up Gabe @ GMS. He could probably hook you up with some track stuff.
758 HP/ 804 TQ
Old 12-02-2025, 08:23 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Did the dealer stop selling them?
bishopts is online now   Reply With Quote
Old 12-02-2025, 09:18 PM   #4
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
Not to hijack but definitely interested in seeing more of your Camaro since we’re both out in Monterey
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 12-02-2025, 10:04 PM   #5
VaporPressure
Drives: '18 ZL1 1LE
KNS brakes is a good source. They have the Ferodo DS2500 pad which is a small step up from the HP1000 OEM pad and can still be used easily on the street.
But based on the other gear on your car, it seems like you'd want a dedicated track pad? I'm happy with Ferodo DS1.11 running slicks and aero. They're high torque, *almost* no fade, and pretty easy on rotors. Good modulation but I haven't tried a ton of different pads. Ferodo 3.12 is the next step up in torque. Reportedly zero fade on those.
VaporPressure is offline   Reply With Quote
Old 12-03-2025, 06:33 AM   #6
ZL1_1LE
Drives: Camaro ZL1
How is the brake dust on the DS1.11? Compared to OEM.
ZL1_1LE is offline   Reply With Quote
Old 12-03-2025, 11:05 AM   #7
AZ_1LE
Drives: 2019 ZL1 1LE
GLOC GS-1's for street
GLOC R10 or R12's for track
https://www.greeneperformance.com/co...rolet/products
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 12-03-2025, 11:20 AM   #8
cdb95z28
cdb95z28's Avatar
Rockauto, Amazon, GM dealerships for the OE Brembo/Ferodo HP1000 pad.
"KEEP THE FAITH"-Fbodfather
Old 12-05-2025, 06:09 AM   #9
VaporPressure
Drives: '18 ZL1 1LE
I couldn't say for sure. It's mainly track use and the wheels do have dust but I don't clean them. But the pads are at least usable on the street. They stop fine when cold (they do squeak a bit but not loud enough to really bother me). One benefit in sticking with a ferodo compound is you can supposedly switch between ferodo pads without concern for re-bedding. So going back to the OEM for street use between events would be pretty simple.
