Old 10-28-2025, 01:40 PM   #1
ZL1_1LE
Drives: Camaro ZL1
Blew a seal, different catch can needed?
Hey everyone, couple of weekends ago driving the wifey to lunch i noticed the smell of oil so immediately pulled over and the car was pissing oil, and the accessory belt was completely shredded. I'm running approx 20lbs of boost with a CPR GEN6 ZL1/ V3 BREATHER TANK that vents into the atmosphere. The car left to get repaired this morning, and I was just wondering if maybe that isn't the appropriate catch can/vent can to help alleviate crankcase pressure, if that is in fact what seal blew when i was driving. Wasn't driving the car hard at all and just pulled off the interstate when I noticed the smell, although I did hear a "thud" when I lost the belt right before smelling the oil. I know it could be a number of things but just wanted to eliminate the easy stuff first or get your thoughts on what may be up. Could be a bad seal, bad belt that shredded the seal, not enough crank case ventilation, a number of things. Thanks for your thoughts.
ZL1_1LE is offline   Reply With Quote
Old 10-28-2025, 02:37 PM   #2
Katech_Mike
Drives: 2015 Camaro ZL1
The belt breaking is what tore the seal. Not the other way around.
Install the LS style seal when you repair it.
Your crankcase vent set up is fine.
Katech_Mike is offline   Reply With Quote
Old 10-28-2025, 03:53 PM   #3
ZL1_1LE
Drives: Camaro ZL1
Awesome Mike thank you! Belts go bad at 18k miles on the car? Any upgraded belt i could use on the accessory side?
Old 10-28-2025, 05:12 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
My shop had LT and LS rear main seals hanging on their wall. I can't believe how much stronger the LS feels. Mine must have become organic because it has stopped leaking... for now.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-29-2025, 05:20 AM   #5
ZL1_1LE
Drives: Camaro ZL1
Heard back from the shop and Mike was spot on, car is getting a new LS seal, new balancer, belt etc
Old 10-29-2025, 02:38 PM   #6
Mark R
Drives: 2018 ZL-1
A penguin was driving his car, and had some issues with it. So he pulls over at a repair shop. The guy tells him it will be an hour or so, and he can go across the street to a convenience store to get a snack. The penguin gets some ice cream, and because he has flippers, not hands, it gets all over his face. When he comes back to the shop, the mechanic comes out and says, "Looks like you blew a seal." The penguin says, "No, it's just the ice cream."
Old 10-29-2025, 02:40 PM   #7
ZL1_1LE
Drives: Camaro ZL1
Dad joke of the year.
Old 10-29-2025, 04:44 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Gunkk is online now   Reply With Quote
Old 10-29-2025, 05:53 PM   #9
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
When I saw this thread that joke was literally the first thing I thought of.
Old 10-29-2025, 06:24 PM   #10
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Didnt someone else have this same problem the other day?
Old 10-30-2025, 10:03 AM   #11
Stoner
Drives: 2017 ZL1 HBM, M6
Stoner is offline   Reply With Quote
