Old 10-22-2025, 08:10 PM   #1
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Steering Knuckle Upgrade - Using OEM Blackwing Precision Pack components
Hey everyone,
I made a video showing how to replace the OEM Camaro steering knuckle with the OEM Blackwing Precision Pack parts. This allows you to get as much as -3.1° of camber up front on the SS 1LE without having to go to an aftermarket solution like camber plates. The part numbers and torque specs and all that jazz are in the description. Previously I was only ever able to get -2.7° at the most if I was lucky. I tested this out at Road Atlanta before I headed out there and set the car up with -2.8°/-2.7° up front. Tire wear on my SC3R was phenomenal.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 10-23-2025, 12:04 AM   #2
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Nice work as always, thanks again for your videos.
2004YZFR1 is offline   Reply With Quote
Old 10-23-2025, 08:51 PM   #3
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
Good video. It inspired me to try and do the same. Ordered the parts and we’ll see
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 10-24-2025, 10:19 AM   #4
FollowMyLine
Driver for Hire
Awesome! Update us after the install!
Luan Zeqollari
YouTube Channel
Old 10-24-2025, 10:37 AM   #5
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Appreciate the post/video...wasn't aware of the option. Thanks!
Tim M is offline   Reply With Quote
Old 10-24-2025, 08:05 PM   #6
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Is this just for the SS-models? I know the rear control arms are also aluminum vs stamped steel as the ZL1 parts. Just didn't know if the front arms had any benefits over the ZL1 parts or if they are the same.
Patriot Motorsports USA is offline   Reply With Quote
Old 10-25-2025, 10:38 AM   #7
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Is this just a track benefit?
Is there any benefit for a vehicle that rarely or never sees a track to do this?
I know it is about getting more from the alignment.
2018 Blue 1LE is offline   Reply With Quote
Old 10-25-2025, 11:14 AM   #8
FollowMyLine
Driver for Hire
This would be for all models. The ZL1 and SS 1LE use the same front steering knuckle. As far as the ZL1 1LE goes, it already has the adjustable camber plate at the top of the strut, so it would be a minimal benefit, but it would still allow for more adjustment than before.
Luan Zeqollari
YouTube Channel
Old 10-25-2025, 11:15 AM   #9
FollowMyLine
Driver for Hire
If you have no intention of tracking the car, there is no added benefit for daily or street driving with these knuckles.
Luan Zeqollari
YouTube Channel
Old 10-27-2025, 02:02 AM   #10
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
What exactly is different with these knuckles? Is the casting different or did they drill the holes in a different spot?
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 10-27-2025, 11:09 AM   #11
FollowMyLine
Driver for Hire
It looks like the upper hole is slightly repositioned, and they also made the neck of the knuckle a little thicker. The material up at the top looks like it was removed, too, so that the knuckle can kick in further at the top before it hits the shock body.
Luan Zeqollari
YouTube Channel
Old 11-11-2025, 03:54 PM   #12
S.Macias
S.Macias's Avatar
Alright, so I not only replaced the stock front knuckles with the Cadillac performance ones, but lengthened the upper knuckle bolt to allow the knuckle to almost touch the strut. Swapped in new outer tie rods and new wheel bearings while I was at it. I have an alignment scheduled for this week, but as it stands on the digital level, I’m at -4.9 up front on the driver side with -4.5 on the passenger. Visually, you can see the more aggressive camber. I’ll have the shop dial out to -3 front and -2 rear.
Old 11-11-2025, 11:13 PM   #13
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
did you try that same modification to the strut before you went to a different knuckle?
Old 11-12-2025, 12:11 AM   #14
S.Macias
S.Macias's Avatar
Nope, probably could have saved myself a couple hundred dollars if I just modified the knuckle bolt beforehand, but I wanted to make sure I could get to -3 fronts without further issue. Figured it all ended up being hundreds of dollars cheaper than camber plates, so it’s a win in my book. But I believe just extending the bolt hole will let you hit -3 according to other forum post
https://www.camaro6.com/forums/showthread.php?t=526353
