Old 10-21-2025, 08:41 PM   #1
sscentex
Drives: 2016 Camaro SS
Odd random rapid blink
I’ll preface this by saying I bought the car used so not certain what alls been done to it.
Every time I use my turn signals they’ll blink normal and then I’ll get a random 1-2 rapid blinks and then it’ll go back to normal. Anyone got any idea what this could be? Car is a 2ss model.
2016 Camaro SS
sscentex is offline   Reply With Quote
Old 10-21-2025, 10:12 PM   #2
clyde
clyde's Avatar
Drives: broken
The same kind of thing happened relatively frequently at random times on the 2017 LS I used to have, but it's been pretty rare on the 2020 2SS I have now (and have put a similar amount of miles on)
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
Old 10-21-2025, 11:18 PM   #3
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Drives: 2023 Camaro 2SS-1LE VOM 6M
On my 23 2SS if I use the turn signals but only tap not fully engage down the stalk R or L my signals blink 5-6 six times and turns off, I use it a lot.
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
pitrott1 is offline   Reply With Quote
Old 10-22-2025, 06:38 AM   #4
ZL1_1LE
Drives: Camaro ZL1
Not sure how familiar you are with newer cars in the last decade give or take, but if you tap the turn signal up or down, it will blink a few times helping you to change lanes, instead of staying on then you fully compress it.
ZL1_1LE is offline   Reply With Quote
Old 10-22-2025, 06:50 AM   #5
I think OP is talking about the blink frequency changing to rapid, as though a bulb was out, then back to normal on its own. This isn't the "tap for 3 blinks" feature you guys are pointing out.
I haven't experienced this at all on my 2018, either with stock incandescent turn signal bulbs or with the LED replacements I've been running for years. Could be the bulb starting to go out, or perhaps a different BCM "error signal" I'm not aware of.
Sorry for not being more helpful, but this is a strange one indeed. I'd first check for non-stock wiring around the headlight harness and the underhood fuse box and see if anything is loose, fraying or broken.
Old 10-22-2025, 07:09 AM   #6
ZL1_1LE
Drives: Camaro ZL1
Hmm good point, maybe the previous owner installed something that has started to go wonky....like arpad said, check for any aftermarket wiring to the battery, good catch arpad!
Old 10-22-2025, 07:43 AM   #7
sscentex
I’m familiar with the tap and that’s not it. I use that a lot. I’m talking about engaging them fully like sitting at a stop light.
2016 Camaro SS
Old 10-22-2025, 08:41 AM   #8
Abubaca
Abubaca's Avatar
Drives: 2016 SS
On my e46 BMW, with incandescent bulbs, I'd get this very thing. Was due to a poor fit between bulb and socket. I replaced the bulb a few times with no luck. Wired in a new socket and all was well after that.
Abubaca is offline   Reply With Quote
Old 10-22-2025, 12:06 PM   #9
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I'd assume a wiring gremlin. I've never seen my car do this.
speedyink1 is offline   Reply With Quote
Old 10-22-2025, 01:08 PM   #10
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
I had this happen on my 2019, and after noticing a few lights wasn't working I took it to the dealer and it turned out to be water intrusion in a few of the connectors and had to be replaced, I hope this is not the case as it was a lengthy process to diagnose and a little costly
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
Justcruising is offline   Reply With Quote
Old 10-22-2025, 01:38 PM   #11
sscentex
That would suck. I’m wondering if it’s not a gremlin though. Brand new battery and the first start of the day is slow and long. Starts fine after that. Doesn’t match the usual slow to start when hot I’ve read about. Could be a small drain somewhere tied to the blinkers. Joy.
2016 Camaro SS
Old 10-22-2025, 01:40 PM   #12
clyde
clyde's Avatar
Drives: broken
I'm not the OP, but in my case, this is correct. Blinker is blinking normally, a couple will happen more quickly, and then the normal pattern resumes.
To some of the ideas mentioned, both cars were bought new, so no "previous owner did something weird" (and on the 2020 car, it was happening before the current owner did something that could potentially be weird). No water intrusion issues. No loose connections anywhere that I've found (and I'm more hands on than many).
It's really subtle and if you're not paying attention, it's easy to miss. I've commented on it to other people in the car that tend to notice these kinds of things and they didn't notice.
It was more frequent in the 2017 car, but as soon as it happened in the 2020 car, I figured it was a Camaro thing and stopped thinking about it.
clyde
Team WTF?!
Old 10-22-2025, 06:11 PM   #13
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
My wife’s Chevy will blink at faster intervals when there was a bulb out.
RIPws6 is offline   Reply With Quote
Old 10-22-2025, 07:38 PM   #14
sscentex
Normal and that’s with every blink. This is not. This is blink-blink-blink-blinkblink-blink-blink.
2016 Camaro SS
