Go Back   CAMARO6 > Marketplace > Members Classifieds > Interior Parts & Accessories
Old 10-12-2025, 12:50 PM   #1
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Brey-Krause Harness Bar R-1155
The paint is scratched where a fire extinguisher was mounted. There is slight cosmetic damage to the paint. Removed it because I added a roll bar. All B-K parts are included.
Local pickup or will meet if close to the Houston area. $450
Below is the description from the B-K site.
The R-1155 harness mount bar is made to mount shoulder harness in a 2016-present Camaro with stock seat sliders. The R-1155 harness mount bar utilizes wrap around shoulder harnesses for both the driver and passenger along with clip in mounting points for the lap belts.
The bars are easy to install and remove, use only existing holes and mounting points, and will not damage the car in any way.
The 6th gen Camaro harness mount bar has been tested and certified by an independent lab to handle the types of forces required by the National Highway Traffic Safety Admin. DOT and SAE J385 Rev.MAR 95, Motor Vehicle Seat Belt Anchorages-Performance Requirements. The Camaro harness mount bar properly locates and supports racing shoulder harnesses relative to the driver. In the case of an accident, it helps protect the driver's shoulders and spine. The harness guides also prevent excessive shifting and fatigue of the driver during the high G loads of cornering and braking.
Strength requirements for harness mounts are considerably greater than those for harness guide bars since they must support the entire load applied to the belts. A mount really can't be relied on unless it has been tested to support the loads required by the National Highway Traffic Safety Administration. The Brey-Krause Harness Mounts support the loads specified by the National Highway Traffic Safety Admin. DOT for upper torso restraints in all automobiles. Tensile tests performed by an independent lab.
Features:
Harness guides prevent shifting of belts in high G turns
Requires no modifications
Tested by an independent lab to exceed DOT, SAE, and NHTSA standards
Properly locates shoulder harnesses in relation to the driver
Integrated outside lap belt mounts
