Old 10-06-2025, 09:51 AM   #1
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
Question DIY shark fin camera questions
I am trying to make my rear dash camera, aftermarket of course, fit into the shark fin.
1) is the only thing in there the OnStar and SiriusXM antenna's? I do not use either so the loss means nothing.
2) it looks like the OEM shark fins are different between the 16-18 and the 2019+, more of a flat face on the newer ones.
Can someone confirm this?
Anyone have a part number for the 2019+? I know, color issue between the blue from those years but I could go black or have it painted.
Any thoughts on this?
I have tried the license plate placement, but that seems too low.
Put it inside, but the picture quality is horrible even though it is 2.5K.
2018 Blue 1LE is offline   Reply With Quote
Old 10-06-2025, 10:19 AM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
2020+ higher trim cars for the rearview mirror camera with the LCD in the mirror. I don’t believe the physical design of the regular mirror without LCD was changed throughout the 6th gen otherwise. There was one person here that essentially modified the standard shark fin to become the rearview mirror camera which involved lots of fabrication on the antenna
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-06-2025, 05:46 PM   #3
2018 Blue 1LE
I have watch many of the online videos.
Other than one, probably the one Bumbleboy92 is referring to, they all were utilizing the same idea as Gen5diy's upgrade.
The video where he drilled the shark fin would not pass my OCD/ADHD desire for perfection which is why I was asking about the newer shark fin having more of a flat surface for the camera tether then the pointed sloped surface.
I am not am not looking to use the factory camera or wiring, but use my dash cam rear camera.
Old 10-06-2025, 06:39 PM   #4
Bumbleboy92
Long hauler
Found the photo I took when adding the OEM camera antenna to my 2016 1LT
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-06-2025, 07:32 PM   #5
2018 Blue 1LE
In the marked up photo, see the shape difference overall in yellow and then specifically at the tip/end/face, in red.
I think the flatter red section of the newer fin would allow for better camera mounting and seal
Old 10-07-2025, 01:17 AM   #6
Bumbleboy92
Long hauler
That’s the point of the newer fin, it already has the rearview camera integrated into it at that point. It’s one part so you’d have to try your luck with buying that entire antenna and taking it apart
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-09-2025, 09:50 PM   #7
p47dman
Drives: 2024 Camaro 1SS
I installed the camera into my OEM fin. I did not like the shape of the one from Gen5diy, although nice, but I wanted red, not CF. Easy to do, but you do need to modify the antenna. IMHO, it looks factory.
p47dman is offline   Reply With Quote
Old 10-10-2025, 12:10 AM   #8
2018 Blue 1LE
Part of the reason I was asking about the shape of the newer one with the camera and what the antennas in there are for.
Again, if they are just for the OnStar and SiriusXM, then I don't care because I do not use those.
If it is an OEM Camaro fin, then it will be hard to tell any different from early to later version. If it is flat faced, then it will work better than the non camera fin.
The product in this photo would NOT pass my quality control!!!
Old 10-10-2025, 12:55 AM   #9
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Sorry was dark and a little moist out. The back up camera, is located just above the license plate, next to the trunk open button about 2-3 inches to the left of it.
Old 10-10-2025, 08:25 AM   #10
p47dman
https://www.camaro6.com/forums/showthread.php?t=627119
Old 10-10-2025, 09:43 AM   #11
2018 Blue 1LE
That I could be happy with, nice job!!
Did you keep the internal stuff, antennas, operational?
Old 10-10-2025, 07:57 PM   #12
p47dman
Yes, everything still works as it should. Although, I did need to modify the antennas a bit.
