![]() Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
I finally decided on Procharger
My Cars getting a P1X with ~7psi and LT4 Fueling installed over the weekend, I decided I wanted a Procharger because I really only do roll races so I want the top end and I already slip enough N/A so I cant imagine a PD Blower without Drag Radials.
What do you guys predict itll put down on the Dyno? I already had a 225 Cam, MSD Ported Intake, Kooks 2 inch LTH and Ported OEM Heads. I'm super excited and cant wait to see the results, Tuner said I still will be limited to 91-93 unless I run a low blend of E, roughly E30-E50 unless I go port injection, but hey ill take it. |
![]() Drives: 2010 Camaro SS Join Date: Jul 2022
Sorry I don't have any input for you considering I have a 5th gen (2010) with a Procharger (D-1x). But I am curious as to where you are having your work done. I am in Denver as well and had my build done at American Intense Racing in Watkins but am always looking for other good builders/tuners.
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
I would imagine the elevation is going to hurt, so I'll guess 610 whp. Why stop at 7 psi?
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
Moderator
Looks like the OP has a stock bottom end.
Mine is also stock bottom end.
Because pump gas...with some additive or meth injection he could push further like you have done but pump 91-93 only he is going to be limited.
#7 |
Definitely, I wouldn't even try 91... I initially dyno'd at 722 whp on 93 with no additive, I run Boostane as a precaution and it probably has contributed to the longevity so far at 12 psi.
#8 |
Moderator
Doesn’t mean it’s a good idea…
Without full E you’re filling the dice over 650 WHP in my humble opinion. For every SBE guy that gets away with it we have 15-20 that don’t and wonder why they have broken ring lands.
#9 | |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Who tuned it? How many miles since the build/ tune? At WoT ~ 6 K-RPM What is your A/FR like? Spark advance Deg.? Injectors Pulse Width ms ? 722 R-WHP on 93 pump is quite a number....
#10 |
Yeah we practically have the same build except my cam is BTR 225, I was told by many that 9psi Is probably the most I could get away with and I also plan on running E50. I’m playing it safe because tbh I was pretty happy with how fast I was FBO heads cam but I just want a little bit of an extra punch on the top end, I also daily mine so I don’t want to drive around a 800+whp beast all the time, 600-700 is where I’ll be happy.
#11 | |
6,000 RPM - .82 AFR, 16 degrees, 4.8 ms - 7,000 RPM is 15 degrees and up to 5.5 ms.
#12 | |
#13 | |
#14 | |
These figures are on 93 pump, right? Amazing stuff for an SBE ! 10K Miles and it is still alive ![]() How much RWHP approximately do the LTHeaders contribute? and do you still run with CATs, or did you remove them? How much does the Cam contribute ? |
