Old 09-03-2025, 05:51 PM   #1
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Heads/Cam 2650 Dragy
Just curious if there are some people out there running the Dragy with their ZL1’s. I recently did some testing after having the trans tune dialed in. Full weight on 20’s managed some pretty consistent 4.6’s with some wheel spin. Very happy considering the setup isn’t aggressive at all and still SBE.
Majority of whats done:
-BTR Stage 1 Cam
-FRE Stage 2 stock castings
-SBE
-TSP 2” stock muffler
-9.45/3.4 pulleys
-Magnuson 2650
-112TB
-+65’s
-LPE HPFP
-DSX Aux
-JMS on factory low side
-E60 Fuel
-20x11.5 315/30 Toyo RR Rear 20x10.5 Front 295/30/20 Firestone Firehawk Indy 500
CamOnlyJabroni is offline   Reply With Quote
Old 09-04-2025, 05:22 AM   #2
clg82
Drives: 2020 Camaro ZL1
I just got my dragy in the mail last week and then went on vacation. Will know my times hopefully this weekend and will post. Where did you mount yours?
Old 09-04-2025, 07:04 AM   #3
CamOnlyJabroni
I need to get a mount. Right now I sit it next to my wideband in the corner of the dash and most of the time I keep my hand on it while making a pull.
Old 09-04-2025, 07:12 AM   #4
clg82
ok haha, mine came with a magnetic mount with 3m tape
Old 09-04-2025, 07:14 AM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I'd say mid 4's is pretty dang impressive! I'm going to get a dragy once I finish my build. If I break into the 4's at all with the M6, I'll be beyond happy.
Mods being installed-
Old 09-04-2025, 07:18 AM   #6
clg82
I didn't see where the dragy said it equated a 4.6 to 1/4 mile times. Do you have that info OP?
Old 09-04-2025, 08:00 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This is 60-130 testing starting from a roll. Ain't nobody with this kind of power out on the street doing 1/4mi pulls. The car is going to spin to the 330ft and probably run somewhere in the 10's. Put it on a drag pack and take it to MIR, it will probably run low 9's @ 152-153.
Old 09-04-2025, 08:58 AM   #8
clg82
Oh no I agree, I just remember seeing a spot on the draggy app where it said 1/4 time, so I thought it would equate whatever 60-130 pull to the estimated 1/4 mile end time.
Old 09-04-2025, 11:02 AM   #9
CamOnlyJabroni
There is a generic chart for trap speed but I never saw anything for 1/4. Agreed spin city especially on 20’s trying to do 1/4 mile.
Old 09-04-2025, 05:14 PM   #10
CamOnlyJabroni
Got 325/30’s on closeout for $200 off each. Going for 4.4-4.5 on 20’s full weight.
Old 09-04-2025, 08:11 PM   #11
SWFLZL1
Drives: 2022 ZL1
Sweet! Let us know how you like them, been trying to decide my next rear tire, and wether to stick with the 305’s or try to go a little wider.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 09-04-2025, 08:36 PM   #12
CamOnlyJabroni
The time I posted was with the 315/30 version. I will try these out and see how they do and report back. Should be better since I have a 11.5 wide wheel which should fully utilize a 325 width.
Old 09-06-2025, 03:29 AM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I have a somewhat similar build but I have port injection.
I have the 80mm upper and 9” lower. I run about the same 60-130 on 18psi, e65. Low side is fore triple.
How much max boost are you seeing with your bigger lower?
I make about 1000whp on a dynojet.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 09-06-2025, 10:33 AM   #14
CamOnlyJabroni
Above 65ish degrees I see just over 17 at 7,100 and if it’s cold out it will go up to 18.5.
