Old 08-19-2025, 07:59 PM   #1
beowulf556
Drives: Camaro SS 1LE M6
LT2 manifold and foam
Working on installing the LT2 intake manifold and I have questions regarding the foam. I cut the back portion like I’ve seen in videos and on here, but when I test fit the manifold won’t sit flush. Is the foam meant to compress a little bit when the manifold gets tightened down? This is a GPI modified manifold but I also shaved in between the runners thinking it would help with the foam clearance.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 08-19-2025, 08:02 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Did you cut the supports off the bottom of the intake?
Old 08-19-2025, 08:10 PM   #3
beowulf556
Are you talking about the rear bottom? Yes it was shaved by GPI.
Old 08-19-2025, 08:35 PM   #4
bishopts
bishopts's Avatar
Have you tried fitment without the foam in place?
If it sits normally then i would say slap the foam in and compress it with the intake
Old 08-19-2025, 11:02 PM   #5
beowulf556
Just tried fitment without the foam and it's perfect. Really want to keep the foam though. Here is a pic of how I cut the foam and the bottom of the intake. Any suggestions are appreciated!
Old 08-19-2025, 11:07 PM   #6
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
When I was researching this mod, it was my understanding that you lose the foam. I'm not aware of anyone that retained it.
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
tortilla-flats is offline   Reply With Quote
Old 08-20-2025, 04:20 PM   #7
beowulf556
I got it installed! Ended up shaving in between the ports more and it fits well with the foam.
Old 08-25-2025, 02:02 PM   #8
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
did you take a pic of the 'shaving between the ports' that worked?
Old 08-25-2025, 04:15 PM   #9
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Yeah, I want to see it too!
Please and thank you!
Dabjbr is online now   Reply With Quote
Old 08-25-2025, 06:46 PM   #10
beowulf556
Unfortunately I didn’t take pics of my final trimming but here is a pic of what I’m referring to. Take the foam off the engine and put it on the intake manifold and you’ll see why it makes sense to shave these areas.
Old 08-26-2025, 06:27 AM   #11
tbair64
tbair64's Avatar
Drives: 2022 Camaro LT1
I would be interested to hear your feedback on performance gains with this swap.
tbair64 is offline   Reply With Quote
Old 08-26-2025, 07:07 AM   #12
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Shaving those ridges is key in order for the intake to sit properly on the foam
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 08-26-2025, 02:44 PM   #13
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I didn't get the LT2- it hadn't come out yet, so I sprung for the MSD and this issue of "foam or no foam" came up. There didn't seem to be a definitive answer. The foam may diminish the sound of our direct injection system and other sounds some people don't like but it doesn't bother me. O/W it looks to me likely to retain heat and do away with any chance of cooler air passing under/around the IM.
So, I left mine off and have had no regrets about it. To the best of my knowledge none of those who chose "no foam" have had any adverse effect.
Ventmaster is offline   Reply With Quote
Old 08-27-2025, 11:10 AM   #14
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Appreciate this
