Old 08-15-2025, 01:22 PM   #1
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Laziness no more! (Oil Question)
Took my car to the dealer to get brake fluid changed and oil changed. I was contemplating on doing it myself but buying all new tools and the slight chance I sell the car I thought the cost would be negligible (+/- $40 - $80 compared to DIY) plus I wouldn’t have to dispose of anything; it would be done quicker possibly.
Anyway long context. It ends up being the (FL)dealer put in AC Delco 5w-30. I swear this car was getting Mobil 1 for its entire life.. however I was proven wrong. They been putting AC Delco for the longest; I haven’t had any issues but just wondering ifs properties are good at not breaking down. The car sits for so long now that not having a high quality oil I’m just wondering if I should just flush and put a better oil?
Overthinking.. but domino affect my laziness.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 08-15-2025, 02:02 PM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I use 5w-30 synthetic blend.
Cars arent as unforgiving as people think.
Old 08-15-2025, 02:45 PM   #3
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Street driving? No problem... Track? If you see higher oil temps it's less than ideal as you want w40. I switched to M1 Supercar 5w50 as it's primarily for ax/track.
Less of a big deal than most might assume, imo, especially if your change intervals are short.
Old 08-15-2025, 03:59 PM   #4
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Thanks! Unfortunately my intervals are time now oppose to mileage nowadays so I’m changing 12 months at a time; maybe a pull here and there but not much aggressive driving. Would love to get it to the track especially since Daytona is not that far neither Sebring but I was overthinking especially with sitting + humidity (so damn hot here) and possibly moisture building up in anyway.
But thank you this puts me more at ease; maybe I’ll change it out sooner then the 12mo and DIY this time around.
Old 08-15-2025, 05:30 PM   #5
Rich292
Drives: 2015 Z/28
There's nothing really wrong with the 5W30 oil as long as you aren't tracking it. If you do decide to do a track day, then yes, you will definitely need to flush it and use a 40 or 50 weight oil.
As far as the AC Delco oil - As long as it has a dexos1 rating (which it does), then it'll meet all the necessary specs for street driving. And that oil very well could be made by Mobil 1, anyhow. GM doesn't make their own oil, they are buying it from a supplier.
In any case, your car will be fine with that weight and type of oil.
One thing I would recommend, though, definitely check how much oil is in the car. Dealers often have the lowest level employees doing the oil changes, and I've seen numerous instances where mistakes were made and the cars weren't filled. The car won't give you an oil level warning until it's very low. So make sure they filled it up completely and you'll be fine.
Rich292 is offline   Reply With Quote
Old 08-15-2025, 05:59 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
My dealer puts in what the manual says.
They enter the VIN and follow instructions. Is your dealer an idiot?
Old 08-15-2025, 06:05 PM   #7
DaveC113
DaveC113's Avatar
Yeah, that's not a big deal either, just make sure you do an Italian tune-up every once in a while. You want the oil hot enough to burn-off moisture and fuel, and you want to get the intake valves hot enough to burn off any deposits.
Old 08-15-2025, 07:28 PM   #8
bishopts
bishopts's Avatar
Sorry to tell you but the shitball techs that get paid bare minimum is the ones changing your oil. You may get charged what the manual says but pulling the dipstick to actually check is the last thing on their mind.
Old 08-15-2025, 07:34 PM   #9
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
I’m going to scour through the manual but am I crazy. I swear it was mobil1 only in our car? I thought we had a badge too but I think that was for the later years or maybe I’m just making things up now.
When I got service done in NJ I was positive it was Mobil 1.
Thank you all for the responses though, appreciate it!
Old 08-16-2025, 03:33 AM   #10
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Oil is cheap, parts are not, if you are the LEAST bit concerned, a $100 diy oil change is VERY CHEAP INSURANCE...
Old 08-16-2025, 04:33 AM   #11
sklippi2018
Drives: 2021 ZL1 A10
Definitely agree with this. Dealership is misleading with a $99 oil change (fine print=6-quarts) until you mention or they see you have a Camaro then they say "it's the same as the Corvette" and now costs $210 (10 quarts). Save yourself the $100 and DIY. At 57 I did my first oil change and it was easy and NO LEAKS!
sklippi2018 is offline   Reply With Quote
Old 08-16-2025, 09:02 AM   #12
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
I do my own oil changes and use 0W-40 as recommended by GM. Not messing around with dealer incompetence or outright deception on such an important and relatively simple task.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 08-16-2025, 09:18 AM   #13
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
If op has a 16-18, then 5w-30 is exactly what the manual and computer tells them to put in.
Before anyone brings up the addendum from 2019, NO dealer actually knows about it/remembers it. I went to purchase oil a few years ago for my prior Camaro (2016) and they gave me 5w-30. I then asked for 0w-40 and they told me that will affect my powertrain warranty. So to your point, yeah dealers are idiots, but if op has an older Camaro, they followed instructions correctly.
Op, what if I told you Mobil one is the supplier for AC Delco oil? You have nothing to worry about if you’re not tracking the car. Do not dump out good oil.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 08-16-2025, 11:06 AM   #14
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Yep 18 right before the change for 0w-40. Got it thanks; I think it was more of my math and being content with what I was paying for / making sure it was good oil.
