![]() Drives: 1968 and 2023 Camaros Join Date: Mar 2023
TSB 23-NA-207 Fuel Feed Pipe
My ZL-1 is at the dealership to get this TSB taken care of and they seem to be struggling to get it done. I dropped it off last Thursday night (07/10/2025)and by Friday afternoon it wasn't started and they said they needed 2 days to do it and they would give me a loaner. I said no problem and dropped it off again yesterday 07/16/2025). Contacted them around noon today to get an update and they can't guarantee it will be done today.
For others that had this done, what was your experience? I have attached the TSB and it doesn't look that complicated so I don't get it.
Alan Tibbetts (Formerly ZL1 TIBS)
Aston, PA 2023 ZL-1 Daily driver 1968 Camaro LS408 T56 swap |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2016
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I just live with a little rattle at startup because I'm not dealing with dealership BS like that.
#4 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
Hope you get it resolved and with a positive result... Or just drop the Shop Manager a couple Benjamins with DSX Low-Side setup!! |
#5 | |
Yes I was. I would just turn the radio up but my wife couldn't stand it. Happy wife happy life.
#7 |
The sage continues. The TSB is taken care of and the noise is gone, that's the good news.
They broke a stud on the passenger manifold while dropping the exhaust (it happens, but they probably put a big impact on it rather than heating the nut). The problem is how they repaired it. I am speaking with them now, but initial conversations are not promising.
#8 |
Well after initially being told that this was an authorized repair, the service manager looked at my picture and ordered the correct manifold stud. I dropped the car back off this Monday morning (8/4/25), for them to accomplish this repair. While waiting for my loaner to be ready, I asked the service advisor what they would do if the threads in the manifold flange were damaged. He said that the stud would have new threads. After trying to explain that I meant the threads in the manifold, I gave up and went on my way.
Tuesday afternoon rolled around and I had not heard from them, so I called. The service advisor told me that we were waiting on parts. I asked what part since they had nine days to order and receive the stud. He said they are waiting for an exhaust manifold. I wasn't surprised, I was sure they had damaged the thread drilling out the original stud. This is ridiculous, if the first tech had just taken their time and used heat on the studs the first time, this saga would be long over.
#9 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
My ZL1 was only at a dealership for 2 days. The day it came in and was unloaded from the transport, and the next day, when I bought it and drove it home! So, maybe more like less than a full 24 hours at a dealership! It will NEVER be at another one for all the reasons as you just painful experience. I hope it all works out for you. But, nothing bothers me more than knowing something isn't as it should be with my car and it will drive me crazy until I correct it! Good Luck !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#10 | |
#11 |
Thank you Al Oppenheiser!
#12 |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
100%. I don't take my vehicle(s)...cars, motorcycles, atv's, etc. back to dealers for repairs unless it is a very serious issue that makes the vehicle undriveable. None of them give two sh*ts about quality work anymore. OP's case is a perfect example. It's guaranteed to come back with some kind of damage, either cosmetic or mechanical. I will live with minor issues rather than risk it. Sucks, but it is what it is.
ΜΟΛΩΝ ΛΑΒΕ
#13 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
Anyone have a video with sound clip of the buzz?
#14 |
![]() Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
I replaced mine myself. That sucked ass. The check valve itself failed. The High pressure fuel rail would bleed down over night. My crank time on cold start was 8-10 seconds. I should have just let the dealership do the fuel line, but I already had the top end of the engine apart doing the injectors and regulator.
